Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Mon Aug 22, 2005 7:57 am
Yep, that is exactly what I found. The ECU appears to just invert the #1 coil signal with a low side driver. For the S14, the tach sources 12 V, so you get 12 V pulses instead of the 5V in that quote. No pull-up resistor is needed.
For the S13, I do not know if the resistor is needed. GTR_Shop said it was necessary. Certainly, with 10k you can't go wrong. If the tach does have internal pull-up, then the added 10k won't break anything, and the tach should still function correctly.
