Articles, troubleshooting, DIY's and how-to's for all Infiniti vehicles.
Re: Infiniti M35/45 (2003-2010) - Sunroof/Window Procedures
Postby audtatious » Tue Jan 11, 2011 9:35 pm
Window Operation
If the windows will not operate in the Auto-Mode and any of the following conditions have occurred, the windows should be initialized:
* Battery cable is disconnected
* Power window switch connector is disconnected
* Power window regulator is replaced
* Power window motor is replaced
* Window glass is removed
* Window glass run rubber is replaced
* Power window fuse is blown
Window Initialization Procedure
1. Turn the Ignition switch “ON”.
2. Open the window more than half way using manual-switch (NOT Auto-Mode) operation.
* NOTE: If the window is already open more than half way, go to step 3.
3. Close the window using the manual-switch operation and hold the switch UP for 3 to 4 seconds after the
glass reaches the fully closed position.
4. Confirm the window you are working on is operating properly.
5. Then, confirm all other windows are operating properly.
Sunroof Operation
If the sunroof does not operate properly, and any of the following conditions have occurred, the sunroof should be initialized:
* Sunroof motor is replaced
* Sunroof anti pinch function is activated for more than 5 seconds continuously
* Sunroof auto-open and auto-close function does not operate
Sunroof Initialization Procedure
1. Fully close the sunroof. If necessary, press the Close switch several times until the roof is completely closed.
2. Press and hold the Close switch for 3 to 4 seconds.
3. Confirm the automatic operation of the sunroof works properly.
2008 G37s Coupe | Invidia Gemini CBE + HFC's | Cobb Stage 2+ | GTspec FSTB | BC Coilovers | Hotchkis Sway bars |
Eibach Camber kits | R2C Intakes | TBW engine cover | 20" ForgeStar F14's | 6000k HID + Fogs
2007 G35s Sedan | 20% tint | 6000k HID's | LED's | G37 19" Wheels
audtatious
Car: 2008 G37s Coupe - 2007 G35s Sedan
Return to Infiniti Articles
