Eswift »
https://forums.nicoclub.com/eswift-u367.html
Sun May 04, 2003 5:47 pm
2 screws need to be removed to move the ECU
unplugging from harness is not required.
self diagnostic pot and LED should then become easily accesible.
dont know if ECU codes changed at all as OBDII was implemented for 96 model year.
you dont take the ECU apart, you just disconnect the bracket attached to the ECU from the frame of the car.
