rucshaca »
https://forums.nicoclub.com/rucshaca-u63195.html
Sat Apr 21, 2007 9:32 am
TOKICO ILLUMINA STRUTS are adjustable struts .....is there any other advantage over KYB GR-2's ?
KYB GR-2 are cheaper than ILLUMINA. My infiniti i30 is an old car. I do not need "adjustable" fancy stuff, i just need something good, which gives comfortable ride (and luxury too... ).
can somebody educate me on KYB GR-2 pros and cons over Illumina ?
Also, i went to my garage shop and he said, that springs are lifetime and hence we do not want to replace them with Eibach springs ...is it true ? Why do i need these springs when the old can be used ?BTW ...What is the difference between the original infiniti springs and the Eibach springs ....is KYB or Illumina not compatible with original infiniti springs (is the original springs called as "lowering springs" or something else)?
Iam getting confused now...
Modified by rucshaca at 1:09 PM 4/21/2007
Modified by rucshaca at 2:25 PM 4/21/2007
