There are four small battery operated sensors that are part of the valve stem. The sensor transmits a digital pressure signal to four corresponding receivers located in the wheel wells. The BCM translates and controls the illumination of the TPMS light. That's the short of it, it's a decent system and rarely have problems. The occasional sensor failure but that's not too bad. The G35,37 coupe and sedan, do not show the current pressure but the FX,Q45,QX56,M all have display capability. I don't know why that is.OnTheRoadAgain wrote:HOW do those monitors actually work?
I have the same problem with my 2006 M35. Those ** readings and the flat tire light are always randomly coming. Is it possible that the batteries in the sensors are going out? If so can they be replaced or is it just cheaper to replace the whole valve stem? If I get new tires (I have only had it for a short while) do they transfer the sensor from the old tires or just install new ones?SteveTheTech wrote:
Your tire sensors were probably not reset the last time the tires were rotated. The dealer is the only one that can correctly reset them and make the screen display the current pressures.JohnFx wrote:I have the same problem with my 2006 M35. Those ** readings and the flat tire light are always randomly coming.
Each tire monitor has an internal lithium ion battery that is designed to provide ten years of service.JohnFx wrote: Is it possible that the batteries in the sensors are going out?
If replacement is required in most cases the system components are covered by warranty. Putting fix-a-flat in any tire with TPMS will void the warranty on the sensor.JohnFx wrote:If so can they be replaced or is it just cheaper to replace the whole valve stem?
The TPMS unit inside the wheel is actually part of the valve stem. There is a small blue box mounted to the inside of the metal valve stem assembly that sends the signal to the receiver in the wheel well.JohnFx wrote:If I get new tires do they transfer the sensor from the old tires or just install new ones?
A light that comes on... my god, the humanity.trimmerman wrote:Hello,
I have a 04' G35X. I consider these tire pressure monitors to be the single biggest problem with the car. Infiniti/Nissan get your act together. Do not leave us with this unsolvable problem. Sell the new part at a reasonable price and make it easily available. Infiniti/Nissan, You made this mess, you clean it up.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
