ig201983 »
https://forums.nicoclub.com/ig201983-u240509.html
Fri Aug 22, 2014 4:17 am
My scan tool is showing 0.0 on the tps reading. The car is throwing a tps code everytime. Is there maybe fuse or relay? When you are in drive and you try to accelerate the car will not go. Even if you push the pedal to the floor it barely goes until it winds up and then it will go but it won't go above 2500 rpm.
