Big_kid »
https://forums.nicoclub.com/big-kid-u247675.html
Sat Apr 18, 2015 8:39 am
The miss had gotten stronger, occasionally stalling. CEL is on, codes are 34, 51 and 32. Haynes translates these to:
34: Knock sensor and or circuit fault (it bucks pretty hard, I can see it sensing abnormally strong knocks. The sensor put out .5 volts when I tested it with a meter)
51:Fuel injector signal fault. I haven't looked into this one yet. Only so many hours of daylight, and I'm not 20 years old anymore.
32: EGR Control solenoid and or circuit fault. As nasty as the throttle body was, I figured there was a strong chance the EGR was crudded up so I pulled it off to check it. Lots of work laying on my back in a confined space under the van to get that pipe off the exhaust, only to find a light coating of carbon and no significant buildup. The EGR valve itself holds vacuum when moved manually and the port is blocked with my thumb. Pipe and exhaust passages around the valve are clear.
I pulled the cap and rotor to inspect the (cam?) sensor underneath, hoping to find a crack/dirt/something wrong. I blew out a little dust, reassembled and found no difference.
This van is kicking my butt, and I don't like it. My to do list is getting longer and longer, and this van isn't letting me get much else done- not to mention my stress levels going up every time I look at this thing. I just keep reminding myself "THIS is my car payment... THIS is my car payment....THIS is my $10 property tax bill... THIS is my cheap insurance..." Even that is beginning to wear thin.
