Gabes13 »
https://forums.nicoclub.com/gabes13-u92491.html
Fri Jul 15, 2011 5:52 pm
Synopsis:
Recently I have been experiencing a serious electrical short somewhere through my ignition system (constant motor misfire, 2 blown 30amp ignition fuses, 2 blown cabin fuses, and plenty of electrical noise from miscellaneous electrical connections (amps, relays, and unit connectors). After pulling the dash and looking at the wiring, I came to the conclusion its coming from the ignition switch harness. The switch connects to the cylinder that the car key goes into and switches power through out the chassis according to the position the key is in (off, acc, on, start ect.). From the switch, it connects to an interior chassis harness that feeds somewhere into, or near, the Super Multiple Junction.
history
A couple of weeks ago I began pulling the viper alarm system from my car because it was giving me issues. The system was wired into the ignition switch (switch side) in a poor fashion. Instead of soldering the connections, the system wires were just spliced, taped, and zip tied onto the ignition switch harness. I tried to repair the wires as well as I could at the time. Upon my repair, I noticed one wire was extremely burnt near the connection (between the switch side and the interior chassis side). It's burnt (almost black) about one inch in both directions of the connector.
The wire is white with red stripe and receives constant power (off, on and start positions).
Issue
My problem is that this wire runs hot when the car is on. I don't know if it's normal but none of the other wires that receive power run as hot as this white/red wire. I also noticed that this wire is hotter on the switch side than the chassis side, and hottest on the burnt spots by the connectors. The voltage on the wire was also 12.75v on the chassis side and ~12.5v on the ignition harness side.
I believe the wire is "too burnt" and as the current flows through the chassis side, it experiencing resistance at the connector and causing what I think is excessive heat.
I already have a new ignition switch on the way because my current switch has what I believe to be too many repair splices.
I dont know if the burnt connection was from my doing of from a previous owner, but my concern is that I may burn this new switch too if I dont repair the conncetion on the chassis side.
Questions
Would I be ok with just replacing the ignition switch?
If not,
Is there a place I could buy this one particular interior harness that connects to the ignition switch?
Could I just replace the one wire by it self with a new 16 gauge wire from Radio Shack or something?
