idle problems.
240sxcl50
Car: 95 s14
I have a problem with my idle being that it is to low.Its only low if my a/c button isnt pushed in no a/c or if the defroster button isnt in. The idle isnt like 200 rpm but it is about 7 and the car shakes need some thoughts.
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
check you iav
costa_rican13
Car: 1993 s13 coupe
^^^^ditto but its IACV. and also i reccomend checking your MAF(mass air flow sensor) is connected on the intake piping. if your problem is still not solved then i say replacing all the gaskets for the entire intake manifold. it will take you a good 4-5 hrs, depending on experience and knowledge of cars, also variety of tools you have as well. this should give you the correct idle if all this is done properly.
240sxcl50
Car: 95 s14
ok. but uhh what is a IACV
costa_rican13
Car: 1993 s13 coupe
its the IDLE AIR CONTROL VALVE. the 2nd biggest hose on your intake piping that goes under and inside the middle of the intake manifold goes to it. there is a screw in the back of the intake manifold on the side of the passenger. unscrew it(raise idle) screw it in farther(lower idle)
vancouverbc
Car: 1991 240sx
costa_rican13 wrote:^^^^ditto but its IACV. and also i reccomend checking your MAF(mass air flow sensor) is connected on the intake piping. if your problem is still not solved then i say replacing all the gaskets for the entire intake manifold. it will take you a good 4-5 hrs, depending on experience and knowledge of cars, also variety of tools you have as well. this should give you the correct idle if all this is done properly.
he has a low idle not a high idle
s14danny
compression check?
vancouverbc
Car: 1991 240sx
240sxcl50 wrote:I have a problem with my idle being that it is to low.Its only low if my a/c button isnt pushed in no a/c or if the defroster button isnt in. The idle isnt like 200 rpm but it is about 7 and the car shakes need some thoughts.
sounds weird. i guess the aac valve could be blocked and you have the idle adjustment screw in all the way and the throttle plate is binding. the ficd valve opens when a/c is on which lets extra air in. the ficd and aac and fixed idle hole are all part of the iacv.
vancouverbc
Car: 1991 240sx
s14danny wrote:compression check?
it idles ok with ficd open
