fozzidouni »
https://forums.nicoclub.com/fozzidouni-u37033.html
Sun Feb 05, 2006 8:34 pm
I just purchased a 2002 Infiniti I35. Basically... It's a Nissan A33 Body (also used on the Altima, Maxima, I30, Cefiro and probably more). With a Nissan VQ35DE Engine (also in the Altima, Maxima, G35 and new M)... All of which have Turbo Kits avaialbe... why the hell can't I find a turbo kit for my car? or is there something about my car that would make it unsuitable for a turbo setup? Here are some specs that will help fill in details if needed.
2002 Infiniti I35 Specifications Quick Specs Submodels: Base Body Styles: 4-Dr Sedan Engines: 3.5L V6 Transmissions: 4 Speed Automatic Drivetrains: Front Wheel Drive 2002 Infiniti I35 Performance & Efficiency Standard Features -3,498 cc 3.5 liters V 6 front engine with 95.5 mm bore, 81.4 mm stroke, 10.3 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder VQ35DE -Premium unleaded fuel -Fuel economy EPA highway (mpg): 26 and EPA city (mpg): 19 -Multi-point injection fuel system -18.5 gallon main premium unleaded fuel tank -Power: 190 kW , 255 HP SAE @ 5,800 rpm; 246 ft lb , 334 Nm @ 4,400 rpm
