I30 tach in s13 cluster. Success! Lots of pics! Tach for 6 cyl!
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Like the title says, this is the I30 tach into the s13 cluster. This conversion uses the I30's V6 tach so you can have accurate rpm's with a 6 cylinder engine! It looks more clean and modern than the J30 conversion IMO. Lots of pics and descriptions for you to do it yourself.****requires cutting, soldering, and drilling****I did this in about an hour and I had to pioneer it. It's pretty simple.DISCLAIMER: Not responsible if you want to copy my awesom-o-ness!
Start with I30 cluster and take out the tachometer.
Three screws in the back, couldn't be more simple.
Cut about a 1/2" off the bottom. Cut piece should look like this...
After you take the s13's old tach & clock out do some trimming on the inside.*A pair of needle nose pliers are great to just break it out*
Then take the I30's tach and thread the 3 mounting screws in evenly.Put lots of nail polish on the top of the screws and sit it down into the cluster to mark the holes you have to drill. (clever)
After drilling test fit it and make some wires with eye crimp-on ends.*Top left is ignition**Bottom left is ground**Top right is tach signal*Also, note that the plastic/copper was cut out around drilled holes.
Make note of the yellow line and circles! CONNECT THESE! This is where the ignition wire needs to go (top left, use an eye crimp and just put it under the screw.)The black ground wire (bottom left) needs 3 eye crimps. Its easy to just follow the copper in the plastic or just look at this picture.If you see where the plug hole is cut into you will see that you also have to shave that part of the connector off also. This is OK because these wires can be relocated (see next step)
This step require soldering in 2 places...The 1st is the middle contact. ILL+You need to solder in a wire onto the resistor before it goes in. there is already a solder there so you can just heat it up and stick a wire in.The 2nd is the bottom contact. HICAS, don't know if its needed but i did it anyway.You need to solder a wire onto the copper pad before it go's under the plastic. (I did this after I took the pic, sorry)The top contact is TAM (tachometer signal) just for your curiosity.These 3 wires (TAM, ILL+, and HICAS) need to be wired into the wires that used to be in the connector before cutting it to fit the new tachometer's chip board.
OK, you got the wiring down now back to fitment.Note the hole I drilled into the bottom of the tach, this allows the gauge face to be flush with the black cover. Just take the tach out and fit it onto the bezel to get the hole's position.Also note the yellow pieces on the left and right. They are parts of a plastic squeegee I cut up to make sure the gauge sits flush in the cluster and doesn't droop.
You may also have to trim the line on the back of the bezel too.
Snap the bezel on and make sure there isn't a huge gap here.
And finally, this is what the finished product looks like.The thirst buster cup is from circle K was from the wife and I's custom ice coffee, act like its not there!
I don't have any pics of it lit up at night but when I do I'll post them up. Comments Please P.S. Don't pay attention to the odometer either. It's just a coincidence that the last 3 digits are 666. I'm not evil, really, I'm not!
*edit* fixed picture issues, sorry, I was sorting them.
Modified by Fibre guy at 9:53 PM 8/6/2009
Modified by Fibre guy at 11:52 AM 8/7/2009
Chris28
Car: 92 s13 KA-T
AWESOME!
It almost looks OEM. Definitely a great option for those with rb swaps. Sure beats sending out your cluster!
samxini
Car: '95 240sx w/Kouki conversion
Good job! Somebody get this man a custom title.
Fibre guy
I forgot about the custom title thing... Maybe "Angry Ducky" or something...
kouki munster
Car: 97 base 240
This is much simpler and retains a 100% oem look.
But still a good write up and good idea.
http://www.dakotadigital.com/i...7.htm
xX RB Xx
Car: SE3P, FC3S, FC3C.
Pretty Awesome!
Fibre guy
kouki munster wrote:This is much simpler and retains a 100% oem look.
Total for this gauge at the local U-pull-it was 15$
Thanks for the positive replies guys. First write up.
Hijacker
Car: '92 240sx Convertible
'94 F-150
I like a lot!
Carl H
looks effin good thats for sure but i would mourn the loss of the clock on a daily basis.gotta have a clock somewhere in the car...least thats me.
Fibre guy
My stereo head unit has a clock on all the time so it doesn't get to me. But maybe I should extend the writeup to add the clock back in, its possible.
On a side note, who do I talk to for a custom title?
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
I love this write up! How did you ever get the idea to even use this tach? Any ideas for a replacement tach for the S14 just for sh!ts and giggles? (my rpm gauge acts weird once in a while) Ohhh yeah, someone give this man his title
Fibre guy
A replacement for the s14... that oval-ish tach isn't used in many nissans...4 cyl or 6 cyl?
I came across it when I was nabbing the dual fans from the I30 for my RB (same calsonic p/n as the altima ones) and decided to take a peak at the cluster to eye it up to the 240's tach. Perfect match.
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
AWESOME AWESOME AWESOME!!!
Another incredibly useful and genius writeup!
tomatotyler
Car: 93 240sx coupe
Wow somebody else in Lehigh Acres, never thought I'd ever see that
Very good writeup by the way!
maj Andres
Fibre guy wrote:A replacement for the s14... that oval-ish tach isn't used in many nissans...4 cyl or 6 cyl?
Definetly a 4 cyl.
nos487
Car: 86.5 nissan V6 5speed truck
I like it a whole lot better than my J30 tach. I just wish you would of shared this sooner. Good job!
Fibre guy
Thanks again for the good replies, not a single flame, wooo!
maj Andres wrote:
Definetly a 4 cyl.
I'll see what I can find.
tomatotyler wrote:Wow somebody else in Lehigh Acres, never thought I'd ever see that
Me either. Maybe after I finish my 240's new radiator support I'll show you a RB. By the model of the cookie cut houses in the sig you look to be off of Joel or homestead.
tomatotyler
Car: 93 240sx coupe
Good guess lol, right off of Homestead. I'd love to see the RB
PapaSmurf2k3
Site Admin
Fibre guy wrote:My stereo head unit has a clock on all the time so it doesn't get to me. But maybe I should extend the writeup to add the clock back in, its possible.
Me, I'll make it angry duck or whatever you wanted... if you want it to be something different, let me know.
Damn shame all the pictures are out of focus.
Fibre guy
Thank you. Angry ducky is just fine.
PapaSmurf2k3 wrote:Damn shame all the pictures are out of focus.
The camera I was using is only good for distance photo's not close-ups.
Modified by Fibre guy at 3:41 PM 8/8/2009
adrianfromthecastle
Car: 1992 Nissan 240sx
Awesome write up!
Fibre guy
Also looking into swapping the speedo. With the rb25 the MPH doesn't work right with the stock s13 speedo.Maybe this one will since its from a VG. Will test it. If it works I'm going to make a write up of that swap too.30 more mph, all the better for track use.
Fibre guy
I30 MPH gauge input is the same as the 240's (60mph=1024rpm)
platez808
Car: 1989 Nissan 240SX
I just did this swap. Except with a different tach. Don't know if this has already been discovered but turns out the maxima (95-99) has the same exact tach as the I30 .
The only thing is that this happened..(sorry for the kinda thread jack) zer...d=135
If you guys can check it out and give me a hand that would be great. Thanks ahead of time
jrb92se
Car: 1989 Nissan S13 coupe
i realise this threads old but will this mod work with a single cam cluster
Fibre guy
I can't see why not. As long as it fits, the wiring is easy. The cluster has the name of all of the wire functions if you follow the copper strips. If its not on the strip it will be on the tach's chip board.
Speedo's need a matching RPM=KPH in order to work.Tach's need a matching # of cylinders to the engine your using.
Gabes13
Car: rb20det s13
I just did this on my single cam. It works fine, but how do I know how accurate it is? I found some kind of adjuster screw on the side, what exactly is it for? Can it mislead idle readings? Just asking bc im about to check my ignition timing on my 20 and i want to make sure my tach is as accurate as possible.
Razi
Car: Moo
If the shop has a consult device, they can plug it in and read the rpm info from the ECU.
KyleT
I have everything hooked up correctly according to the pictures on here. When I plugged everything in and turn the key on I could smell something burning. Traced it back to the ecu and found the same resistor is fried that this thread talks about: http://zilvia.net/f/engine-tech/272519- ... -look.html
I dont understand why it fried that resistor, and what should I do now?
R_Webb
Car: 93 Nissan 200SX S13 RB20DET
hi,
I'm trying this out i noticed that i drilled the holes not in the right spot when i put the plastic cover the tach looks a bit off,
my question is that if i want to drill new holes to adjust the location of the i30 tach again will it affect it? because it's on the plastic copper.
R_Webb
Regards,
