sixty4 »
https://forums.nicoclub.com/sixty4-u105667.html
Tue Jul 07, 2009 2:47 am
Thanks for the response!
I found the BG44 at a local shop, they want $21.95 a bottle and great suggestion on it. I read some posts about the stuff, sounds good!I called and got prices on the items you mentioned, not cheap at all. I do my own synthetic oil changes.. how hard are the other items?
$145.99-Transmission fluid must be pinkish red. If dirty/brownish, do a pan drop-clean the pan, magnets, replace filter and gasket and then refill by the exact amount drained. Would be better to have ATF fluid exchange rather than multiple drain and refill (use Nissan Matic-D or Mobil 1 ATF or Dexron III and add a bottle of LubeGard Red ATF Protectant)$79.99-Check/replace power steering fluid (Dexron III or equivalent)-Check brake pads thickness. Minimum is 2mm but since this is a long drive, pads must be 4mm or more. Flush brake fluid if color is very dark.-Check/replace air filter.-Check drive belts and replace if cracked or worn out-Check all lights-Check tire condition and pressure-Take advantage of this long drive to use BG44K or Redline Fuel System cleaner - 1 can each way.$99.99-Coolant$145.00-Transmission Fluid$50.00-Oil (Do myself)
