My 2001 Pathfinder was running just fine yesterday morning. I get home about 4 hours later I go to start it up and nada. It cranks all day but doesn't turn over. It started once after about 3 tries and died only a few seconds later. Naturally I tried to rev it and it still died (its the old car syndrome I have).
Flash backwards to 2 weeks ago. My check engine light came on and we went to Autozone to have it tested. I am 99.9% sure the code was P0100. Don't hold me to that. Check engine light went off a day later. The car has given me ZERO signs of any issues, driven perfectly fine, no stalling, idling funny,no gauges going nuts, no starting issues...nothing.
Flash back 3 weeks ago when I went to the oil change place and they asked if I wanted fuel injector cleaner put in my tank. Sure. Why the hell not.
Flash forward to today. I know very little about fuel injected cars or anything with a computer so I spent most of the day researching everything and anything that would cause my car to not turn over.
I started with the most obvious thing. The battery. I took it to the parts store and they tested it and their lovely little contraption called it a "Bad battery" yay? I replaced the battery and immediately when I hooked it up things didn't seem right. My door bell started dinging and there was a clicking noise. Not good. I thought "Oh god I left the keys in" nope. They were in my pocket. Oooohhhhhkay... Still nothing. Cranky but no starty.
Phew sorry this is long...
I read that sometimes the IPDM (Intelligent Power Distribution Module...or Idiodic Piece of Deceptive Material) will go bad causing a relay to go bad. I have read that you can do a temporary swap on the relays to see if one is indeed bad. The articles I read were for the Titans which apparently the IPDM can be swapped out for theirs because Nissan is evil and doesn't sell them? Nothing makes much sense once I look at my own vehicle. In all reality it will probably go to the shop but I like to have a heads up and try and trouble shoot things on my own because I get screwed a lot at the dealership/repair shops ("Oh the pretty dumb girl doesn't know anything..."
Is a temporary relay swap possible to see if it is my IPDM? I took pictures of my junk in the trunk (ok its under the hood but whatever...) There is no ECM relay only one labeled EGI. Also the instructions suggest to switch out the Fog light relay with the ECM relay. Fog light relay is on the driver side fuse box.
I know there are about 532 other possible problems this could be from a MAF circuit malfunction, bad IPDM, bad batteries in keys, bad fuel pump, clogged fuel line, fried wires or anything else.
just trying to solve this before my husband tries to attack the car and starts to think the worst about having to completely rebuild the engine.
Any and all help is very appreciated. If someone helps me with this and its the problem I solemnly swear to send you delightful baked goods in thanks.
