T45 »
https://forums.nicoclub.com/t45-u41813.html
Mon Oct 01, 2007 1:16 pm
I'm pretty sure you're going to have to drop the lower crossmember in order to get the clearance to get the pan around the pickup. Also you will have to remove some brackets on the engine. I could be wrong but I know it's not as simple as unbolting it because the crossmember and steering rack run directly under the pan.
