Discussion forum for interior styling, modifications, lighting and repair
i think i rear window defoster is broken!
Postby raiders4403 » Thu Jan 28, 2010 11:51 pm
it doesnt turn on anymore! at first one push would turn it on/off, then later i had to push and hold the button for it to turn on, but now nothing! it doesnt turn on anyomre! what the frag !! car has 38k miles so warranty is no more, so if i take it in ill get charged an arm and a leg just to check it! does anyone has any insight on the issue. is this a program like the auto windows? thanks ppl
raiders4403
Car: 2007 VERSA S
Re: i think i rear window defoster is broken! (raiders4403)
Postby Promise Land » Fri Jan 29, 2010 3:46 am
Haven't heard of this issue before. You are barely over your warranty. I'd call the dealer anyway and see if they know anything. That's still free.
Project: MEEP:
Versaspeed Grille
Tiida Xenon HID Projector Headlamps
APR Carbon Fiber Splitter
Custom Lower Mesh Grille
Earl's Stainless Steel Brake Lines
Tanabe NF210 Lowering Springs
Satin Black Spec-V Wheels
35% Tint
NISMO Graphics Kit
Promise Land
Car: 2009 Nissan Versa S 1.8L H/B
Postby xtwoonamatchx » Fri Jan 29, 2010 8:55 pm
I'm actually having the same exact problem with mine (2007 S hatchback). I installed a Headunit, but that was about two years ago. This problem just started happening around Decemeber 1. I took the entire middle dash apart, and the unit itself. I didnt completely disassemble the unit, but the entire face of the defrost unit. I couldnt see anything from there. With mine, if I push in, then move the button around it will eventually come on. I just havent had time to go to the dealer, I have 32,000 miles, so I better go soon =p
Not to thread jack but has anyone heard of the rear washer fluid not working? Mine hasn't worked since I bought the car back in July 2007.
</threadjack>
xtwoonamatchx
Car: 2007 Nissan Versa S
Re: i think i rear window defoster is broken! (xtwoonamatchx)
Postby Promise Land » Sat Jan 30, 2010 2:21 pm
Someone else on here had his hoses not connected to the washer pump when he picked it up. Maybe yours is the same case? The washer hose will run on the top of the headliner on the left side.
Promise Land
Postby raiders4403 » Sun Jan 31, 2010 1:00 pm
xtwoonamatchx wrote:I'm actually having the same exact problem with mine (2007 S hatchback). I installed a Headunit, but that was about two years ago. This problem just started happening around Decemeber 1. I took the entire middle dash apart, and the unit itself. I didnt completely disassemble the unit, but the entire face of the defrost unit. I couldnt see anything from there. With mine, if I push in, then move the button around it will eventually come on. I just havent had time to go to the dealer, I have 32,000 miles, so I better go soon =p
</threadjack>
hey if you do goto the dealership for the defrost problem would you let me know what they find? it would be a great help. thanks
raiders4403
Car: 2007 VERSA S
Re: i think i rear window defoster is broken! (Promise Land)
Postby xtwoonamatchx » Sun Jan 31, 2010 6:28 pm
Promise Land wrote:Someone else on here had his hoses not connected to the washer pump when he picked it up. Maybe yours is the same case? The washer hose will run on the top of the headliner on the left side.
Well when I was putting in my Sub/Amp, I noticed a hose running along the bottom passenger side panels. It looked empty though... Where should I check for the connection?
And raiders, I definately will... I'm going on wednesday hopefully so I will be in touch!... gotta love last minute warranty work =p
xtwoonamatchx
Postby raiders4403 » Wed Feb 10, 2010 7:49 am
figures that i purchased the exxtended warranty and didnt remember! hahaha but i got it fixed, it was the A/C head unit, thats the part where you control the temp and flow of the a/c. the defroster button had a short in the wiring that made it stop working. they replaced that and now alll is well. turned out good for me this time.
raiders4403
Car: 2007 VERSA S
Return to Versa Interior Forum
