whyteboi wrote:looking good.
and is that olivia munn from aots in a makeshift bunny suit???
Looks like it! lol nice.
After the hoses were in place, i decided it was time to install my newly purchased Greddy intake manifold. I thought about getting the ISIS one but for some reason i just couldn't talk myself in to it. So Greddy it was.
I also decided to block off the IACV on this setup so here is a plate that i originally intended on using for that.
I then was worried about it bowing in the center (very unlikely but still) So i decided to step it up and go super overkill.New block off plate
Next, i decided to start working on the wiring harness before installing the intake manifold. I started feeding it through and laid it in to place the way i wanted, obviously i had to extend the o2 harness if i wanted it to be ran this way. Fine with me, i would way rather make an extension harness for that than to run the wiring a way that is less clean.
After that was at least laid out how i was planning, i decided to move on to figuring out the oh so ugly upper heater hose setup. So, this is how it was originally when i purchased the engine.
GROSS!
I was planning out a different way to go about this to make it clean and presentable without cutting the tube that it attaches to. So first was to find a hose that did a "U" shape that i could use behind the engine, the best would be a hose that did a fairly tight "U" I found the one i was looking for and it looks like this once it was installed
I also got an Alloy hose joiner since i dont want to worry about the plastic one breaking ever. I then attached it to the other hose which i cut to fit perfectly and it all went together like this.
I might be back to update more in 5 minutes but i am so tired. I wonder if anyone else is even on here right now.
Modified by OM3GA at 3:19 AM 3/21/2010
