SanCarlosQ45 »
https://forums.nicoclub.com/sancarlosq45-u89021.html
Wed Jan 21, 2015 8:55 am
I'm sure yours if fine, but there was a mid year change in 93 where they made some changes before the new body in 94. Lets say that 1990-92 have 20mm lower mounts and 22mm in 94-96, that is a fact. The 1993 model is a crap-shoot in terms of metal backed chain guides so I'd assume the third member is the same.
Z32 and S13 aftermarket adjustable arms and bushings are all the same. The Z32 ball joints are the same, the cone seat on them is not.
I can go on, I've replaced the entire suspension with either poly bushings or Z32 adjustable, this includes ball joints and LCA bushings. I'm running R32 skyline front brakes which are not the same as the Z32, but mount the same.
