02sixspeedmaximaselover »
https://forums.nicoclub.com/02sixspeedmaximaselover-u49705.html
Sat May 24, 2008 9:49 am
The other day when I was getting into my car leaving work, I notice a pool of oil sitting under the right center middle of the front hood(basically in front of the driver by 5 feet). I checked all the fluids, noticed the motor oil was somewhat low, so I took my 2002 maxima se, 6 speed, into the dealer today for an oil change and to ask about the oil spill. I also have a mechanic that I work with, but I couldn't convince him to swith me over to synthetic so I take it to the dealer where they use 10w 30 Amsoil(though I'd prefer it if they used 5w-30). Anyway, the dealer loves giving me a laundry list of things "wrong" with my car at the end of each service. I was wondering if this forum could take a look at what I got today and make any suggestions/advice, address concerns, and share knowledge.
1) Front & Rear End Mounts (engine), says they're split. This is the cause of the oil spill I noticed the other day. If not taken care of will eventually ruin the other 2 mounts. Labor 1.9hrs $478.
2) Rack & Pinion - Leaking. Says eventually I'll feel a grinding in the steering. Labor 6.1hrs $1400.
3)Left Inner CV Boot - Torn, says its the end inside the transmission, grease is flying around, they put this one at the top of my list. Labor 1.8hrs $264.
4)Check Engine Light - Says its $100 bucks just to run the computer on it. Took it to autozone for free, its an Oxygen Sensor, my mechanic will do it for under $200. Not extremely concerned about this. But easiest to afford.
The car is just at 100k. I don't have the kind of bucks right now to pay for all of this, and I know my mechanic could probably do it for half the cost of the dealer. I've already replaced the engine on this car (earlier post, new engine is at around 60k now), clutch, water pump, moon roof doesn't slide open anymore, and a couple other pricey items I can't remember right now. I love the car, but I can't believe all the maintenance issues I've had with this car. Its paid off, and I don't want to sell it, but with all this garbage its hard not to consider it. I'd love to be able to just fix everything and keep it forever though, definitely with some modifications in the future. Your thoughts? Is there anything I can do on my own? Your advice is much appreciated! Thanks!
