raven2345 »
https://forums.nicoclub.com/raven2345-u70863.html
Tue Dec 14, 2010 11:26 am
In short, after my own arrogance, my loose wiring got caught up in the clutch for the fan on my KA. Well I soldered back together everything that I saw was messed up (MAF wires, and a wire that goes to the ignition coil area). But while doing that, instead of just trying to get it start then and there, I decided to cut off all of the other plugs I wasn't using like the huge IACV plug and a few others. With everything put back together, I'm still not getting spark. From what I can see, the coil is getting the power and signal it needs. However, nothing comes out of the wire that goes to the distributor. I've looked through the wiring diagram, and there is a black and red wire that goes to the coil. It traces back to the ECU, the ignition switch, and the fuse that it goes to. On the other side of that fuse, is a brown wire that traces back to the huge IACV plug... Could cutting that plug have fubar'd something?
There are a few other things I'm clueless about: a light green and black wire that goes from the "resistor/condenser" to the coil, and to the "power transistor"; and what the black wire (looks like a ground) behind the coil is doing.
Thanks guys
edit: I wanted to test my coil but I'm honestly not sure which wires I need to be checking, so if anyone could help me out with that. I've beem through the FSM, but I guess I could've missed it.
