After some research and some mesurements I came up with a solution to mount up the HX35 onto the stock RB manifold with out cutting a hole for an external waste gate. Just to warn you the pictures you are about to see are pretty haggard, and the welding came out pretty ghetto so please don't flame it's all going to get done correctly and proffesionally the next time around.
This is it loosely mounted.
Notice the wastegate flange is facing the compressor housing. ( I take %100 fault, but thats what I get for not double checking my self)
Note the s*** welds. I preheated and got pretty good penetration in some spots, but this is something I should definitely leave to a professional I will grind the welds off this weekend and send it out to get re-done.
This is the adapter I used. I would have bolted it on to the Manifold but the wastegate adapter doesn't leave any space for a bolt or nut. When I take it apart I will show you guys what I mean.
A picture of the car as it sits haha.
Please let me know what you guys think. Remember I'm not a professional by any means. I'm also sending it out to get re-welded. So far it seems it will fit and work ( this was my main concern).
