Finally now that we have the workshop, work can continue on my car!!!
So I've chopped a step out of the sump enabling me to drop the motor around 25mm lower than before
, here I am with the chopped sump bolted to my dummy block + gearbox assembly, about to test fit and check for clearances:
A little bit of pushing, shoving, heaving and grunting on part of Brendan, and GaR sacrificing his elbow against my block for the greater good, and me rushing around like a madman ensuring the driveshaft slid in nicely and the gearbox mounted properly, the dummy assembly sits in place:
Bowl of the sump had a wee bit of interference with a lip on the crossmember, so I had to clamber under there and cut it back by around 8mm to make clearance. I'll seam weld it too, although it doesn't matter as the cut doesn't compromise its strength, being the pressed lip:
Views of the cut I took out of the crossmember lip:
Big chopped step taken out of the sump... I'll get one of the boys from work to tig the new plate for me:
With the engine in position and clearances checked all round (minimal clearance, just how I like it... nice & tight), Brendan chopped me a 699mm piece of 2x4 to slot in between the chassis rails to sit in front of the motor, with the center marked clearly. We used this as a visual basis to check that the engine is centered properly.
So... engine centered? Check.Engine as low as it gets with minimal clearance? Check.Engine isn't tilting to one side? Check.
Last thing to do now is to make cardboard templates of the pieces needed to weld to the plates on the engine, that come down on either side of the crush tube in the mount bush, then cut the steel to shape and weld it in place and voila, brutal engine mounts. _b
Next step will be to rip the sump out and get that welded up with its new shape, and also slap a spare set of heads on the dummy block and begin exhaust header fabrication. Woo, project for the holidays
Girls love a dirty guy, look at that sex appeal!
