How would i adjust my clutch pedal?
j1rm
Car: 94 Accord auto. 90 Z32 (in the works)
when its cold its fine, but as soon as the car warms up, the pedal becomes very hard and i have NO freeplay, as soon as i press it in it engages, could it be more than just the pedal?i recently had my clutch and clutch master cylinder changed, like a week ago could it just need adjusting? and how would i go about doing it?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
you can adjust the master cylinder pushrod at the clevis on the pedal, it shoudl have just a hair of freeplay before it starts moving the pushrod
j1rm
yeah i noticed it was like less than an inch of freeplay, almost nothing
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
Follow this and you can't go wrong.
http://www.twinturbo.net/net/v...80853
This will work for any Z clutch
j1rm
thanks that helped out a lot!
j1rm
well i adjusted it to where i liked it, but now the car wont turn on. now i gotta adjust the small button that the clutch pedal hits
yellow is the part that i think i have to adjust, and green is where i have to adjust?
WAM_Z32
Car: '93 Nissan Fairlady ZX
Looks like you were adjusting the wrong thing chief, now just put it back.Best Guide, with pictures http://www.twinturbo.net/nissa....html
j1rm
i gotta say that IS the best guide, but i did that, i was just saying that i think i over adjusted, can i just zip tie that switch closed and not worry about it?
Zwicked
Did you read the part that says adjust the 2 witches evenly and then the pedal up until it depresses the 2 switches? It's a pretty simple procedure.
*That other adjustment tech link is ok, but it doesn't address adjusting the switches which are important as you've just found out.
Modified by Zwicked at 6:46 AM 2/9/2009
WAM_Z32
j1rm wrote:i gotta say that IS the best guide, but i did that, i was just saying that i think i over adjusted, can i just zip tie that switch closed and not worry about it?
Good rule not to override things unless you know 100% what your doing, you needed to just adjust your pedal play to compensate for ither a grinding, or slipping. I'd suggetst avoiding zip-tieing things....
evildky
06 Nissan 350Z GT
do you still have a touch of freeplay at the clevis?if the clevis has freeplay it's ok to adjustt eh saftey switch, if you preloaded the clevis somethign else is wrong
j1rm
i checked the push rod and and its almost completely out, i over did it
evildky
06 Nissan 350Z GT
properly adjusted there should be no tension on the clevis pin, if it's pushing or pulling on the clevis it's wrong
