cretney »
https://forums.nicoclub.com/cretney-u140383.html
Sun Aug 09, 2009 9:36 am
I have a 1996 Nissan Altima, and about 2 years ago, it started to rough idle. After some internet searching I stumbled on an issue that seems to plague the Altima. The intake manifold gasket apparently fails, and now your air/gas mixture is thrown off, causing the car to idle poorly.
To diagnose the problem, it is fairly simple. Using a propane torch (do not light your torch, just gas...in case you were wondering), you can search around the intake manifold. So, with the car idling, just shoot the propane gas around the intake manifold gasket area, until you notice that the rough idle begins to go away. As you remove the propane from a specific area, the rough idle returns.
Unfortunately, the replacement of the intake manifold gasket is not a simple task, and requires removing a ton of components. I usually would take on most repairs, but this just appeared to be a real headache and decided to pay a pro.
It cost me $550 to get the repair done. It seems to have done the job, and my car is now running fine at 207,000 miles. Except now, my O2 sensor rusted out of my catalytic converter, and I am attempting to repair using a high temp adhesive. I also got the knock sensor code, but I am hoping this may just be a stored code, that will go away after I fix the O2 and get the codes reset.
