allensteiner »
https://forums.nicoclub.com/allensteiner-u79163.html
Mon Aug 31, 2009 2:41 pm
I've decided to fix my sway bar links because the car didn't handle as well as I would've liked it to. I went with MOOG parts because of lifetime warranty. Did the bushings only and reused the OEM links because new ones were $27.99/side After replacing both sides the car handles a LOT better - higher cornering speed and smoother ride over bumps. The cost was $15.98 for both sides.
I could've gotten both new sway bar links off eBay for $20 shipped but there might be problems with quality/warranty in the future so if you decide to go that route keep that in mind.
TOOLS:- tire iron- jack and stand- 12mm and 14mm wrench - I have ratcheting wrenches which make it a lot faster, but you can use a ratchet/socket instead of the 14mm wrench- torque wrench- pry bar- MOOG sway bar bushing kit - 1 box = 1 side, $7.99 at my o'reilly
1. jack up one side and support on stand, remove the jack2. remove wheel3. jack up the control arm to remove tension off the sway bar4. remove the top nut (14mm) - might need to use the 12mm wrench on the lower part of link to hold it steady5. remove the upper washer and bushing6. release the jack7. pry the sway bar off the link8. remove the lower bushing and washer and replace with new9. jack up the LCA10. pry the sway bar onto the link and install new bushing, washer and nut - i reused the OEM 14mm nut, the kit comes with both new upper and lower (LCA side) nut which is 17mm i believe11. tighten the nut as much as possible - should hit a stop on the threads when properly tightened12. use the 12mm wrench to straighten the out the link - needs to look like a straight letter "L"13. release the jack, put the wheel back on and drop the car14. DO NOT FORGET TO RETORQUE THE LUG NUTS WITH THE CAR ON THE GROUND15. enjoy the ride
Modified by allensteiner at 12:05 PM 9/1/2009
