how to swap a s14 vlsd into a s13...........
killablue240
Car: sr powered s13 coupe, 1991 twin turbo 300zx
i bought a s14 vlsd diff from a junk yard for 100 dollars, here are a few pictures of it notice there is no vlsd sticker on it, it came off of an abs model
first i jacked up the car and supported it with jacks and jackstands because im paranoid, then i removed the rear exhaust so that i had more room to maneuver.then i proceded to take the old diff out, you need to remove four 14mm nuts that hold the drive shaft to the pinion on the diff.then you remove 6 12mm bolts on each side of the diff that hold the flanges to the axlesthen you place a jack under the diff pumpkin and remove four 17mm nuts on the back holding the rear cover to the sub framethen you remove two 17mm bolts that hold the front of the diff to the subframeonce its loose you need to maneuver the nose of the diff forward and over the swaybar so that the rear bolts will come out of their holes, once they are out slowly lower the diff and as soon as the rear clears pull the nose back from the sway bar, then move the axles aside and pull out the diff.since i was using a s14 into my s13 i had to swap rear covers and rig up some bushings for the front two bolts.i bought a new cover gasket from checkers for 4 dollars and used high temp red silicone.for the bolts i used the s14 bolts with rubber grommets and washers, i cut the grommets with a hacksaw so that they would sit flushthen i used two washers in between the diff and the sub frame and one washer under the diff.to replace the diff it is just the opposite of removal. here is a picture of the finished productit took me about 20 minutes to jack the car up 20 minutes to get the old diff out and about 20 to get the new one in, the thing that took the longest was changing the rear cover because i cleaned it up real well and had to wait for the silicone to dry. you can either fill the diff up when it is on the floor or when you put it into the car, in this picture i used a bottle of gear oil with a piece of hose to top off the diff it used about i and a half quarts, i also used some lsd additive jsut in case.i took the car out for a spin tonight and it felt very nice it accelerates much better through turns it hooks up better from dead stops and when drifting it is more predictable and flows smoother, also when i hit high boost the "tire" dosnt start spinning, very worth my 100 dollars, also this was a abs unit so the snout of the diff was about 3/4 of an inch longer but i had no problem the driveshaft worked fine.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
nice job, i wish i could find one in a junkyard. I will probably end up buyin one off ebay.
Keep an eye out for a J30, that's a good diff swap as well.
http://www.car-part.com, check your area.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
sweet write up man !be sure to post it in the sticky for a custom title.
callmeweezy724
Car: 1990 240sx w/s13 blacktop swap, 1986 e30 325e 4dr 5spd,1997 infiniti Q45
quick question, did you have an open differential b4 this? or did u have lsd? if i dont have lsd now do i need the axles to use the s14 vlsd?
killablue240
no my car was a 89 coupe with stock open diff. i used the stock axles.
twoeightythreez
Car: 1994 Infiniti G50
1995 Chevy Caprice wagon
1969 Buick sportwagon
Q45's all had VLSD's btwonly prob is that the axles are the 6-bolt 300zx tt style.
Dattebayo
twoeightythreez wrote:Q45's all had VLSD's btwonly prob is that the axles are the 6-bolt 300zx tt style.
You mean 5-bolt 300ZX style. Could you please at least research information before posting the wrong thing?
callmeweezy724
killablue240 wrote:no my car was a 89 coupe with stock open diff. i used the stock axles.
so i can keep my axles and swap to an s14 differential without changing my axles right? sry for thread jacking.
killablue240
yes you can, i used the s14 flanges though they came with the diff i think that they are different than the stock open diff so if you get the diff with flanges you have nothing to worry about.
callmeweezy724
killablue240 wrote:yes you can, i used the s14 flanges though they came with the diff i think that they are different than the stock open diff so if you get the diff with flanges you have nothing to worry about.
ok cool thanks man. again sry to thread jack.
nice_try
Car: '90 240sx with a bone stock sr20 swap!
nice write up man.. gonna help me out alot here soon.
beaux240
Car: 1989 240sx
what size spacer did you use for the bolt. and where did those rubber bushings come from
jgauspohl
Car: 97' S14 SR24VET
92' S13 S14 SR20DET
90' Golf GTI
91' S13 siltruck project
Awesome write up man...I'm going to be doing this on my dd hatch...and q45's do have 6 bolts halfshafts I'm putting one in my s14 track car...please do YOUR research before flaming people that wish to help out the community. :slap:
God I hate...HATE...post whore :bs: know it alls... :werd:
jdns13
Car: 1993 nissan 240sx
On this Diff swap( s14 abs diff into s13) you mentioned that you had open diff, and you have to use the s13 cover and put it on the s14 vlsd/abs. Did you have problem putting the driveshaft back? Was is it a lil SHORT or LONG? how did the stock s13 drive shaft fit on s14 abs diff?
killablue240
the driveshaft worked fine, it was a little long but because of the design it has some wiggle room.
you have to use the cover off your original diff because the s14 is different.
