WhatsADSM »
https://forums.nicoclub.com/whatsadsm-u29596.html
Thu Jun 26, 2008 4:44 am
I will add my info in here.
I actually had to do what rb25drag is talking about to get an accurate timing reading on my motor. When I used the loop wire I got invalid readings... Like straight out WRONG.
Here is the reason. Most (if not all) modern timing lights are set to trigger from the HIGH tension lead. This means the spark plug wire itself on the secondary side of the coil.
However on the RB the loop back wire is actually on the LOW tension side of the coil pack controlled through the ignitor.
So what was happening was this. My timing light was picking up on the increasing current in the LOW tension lead at the very beginning of the dwell. And it would fire the light. So I was getting a light that was occurring SIGNIFICANTLY before the actual ignition event. Doesn't matter if I used the black looped wire, or the white wire on the coil they are all the same. They are the low tension wires on the primary side of the coil and my timing light was able to pick up on the dwell current.
So in my case I was seeing values that said my timing was like 15-20 degrees more advanced than it was. Since I had an EMS I just quickly adjusted the dwell to run my "I think I know what is going on here" test and it verified what I thought. When I decreased the dwell the timing light would show a decrease in timing, which is flat out incorrect.
I then took a spark plug wire I had laying around, unscrewed the coil and attached the wire to the coil and the plug and checked everything again. (By the way there is no need to jam a bolt or anything in there the tiny spring should make contact with the coil and the wire just fine). This time when I measured with my timing light everything was spot on and when I changed the dwell it did NOT effect the readings.
Moral of the story... it just depends on how sensitive your timing light is. But very likely it could be an incorrect value when being read on the loop back wire or the white wire, on the primary side of the coil.... Because, well that is not how timing lights are designed to be used, they are designed to be attached to the spark plug wire itself (HIGH tension) on the secondary side of the coil.
Hope the explanation make sense.
