HOW TO: Replace Electromagnetic Coil for A/C Compressor Clutch
Sstupid
Car: 2007 Infiniti M45 Sport
Hi! I have a 2007 M45 with 198K miles on it. I bought it about 3 months ago for $6400. I'm a shade-tree mechanic and didn't see any indications that this was a bad deal, so I went for it. The seller was a co-worker, so I knew some of the history of the car. It went back and forth between Austin and San Antonio about 4 times per week, which is why the mileage was so high. I knew there would be some hiccups here and there and this is the first, which happened 2 months after I bought it. The A/C stopped blowing cold a couple of weeks ago. I checked the connector at the A/C electromagnet for 12V and had it, so that meant the electromagnet was faulty. Can you replace that part? Sure can.
Disclaimer:
I am not responsible for you getting hurt or messing up your car. Be safe and be careful.
The car:
Tools:
1) 1/4" ratchet
2) Shallow 10mm socket for 1/4" ratchet.
3) 10mm nut-driver, or you can use the ratchet
4) Serpentine belt tool or you can use a 1/2" ratchet with a shallow 14mm socket.
5) Strap wrench or a set of oil filter pliers, or a very large pipe-wrench. You'll see what I'm talking about.
6) Small pry-bar or large flat-blade screwdriver.
Stuff you need that costs money:
1) Electromagnet for A/C compressor clutch: $99.50.
2) Craftsman snap ring pliers - $26.50. You actually need a larger pair than this as well to have the exact right tools, but I couldn't find one. This did work but the job was more difficult because of it.
3) Serpentine belt tool - $15.99 at Harbor Freight
4) (Optional) 6-pack Shiner Bock - $7.99
Infiniti quote to replace compressor - $1947.43
HOW TO:
I don't have photos for the easy stuff, so only do this if you have some mechanical knowledge. Also, the previous owner threw away all the decorative panels from inside the motor compartment of this car, so I don't have any idea how to remove those. I'm sure they are cheap-a**, snap-ins, so I'll leave that up to you. You need to remove the front left and right decorative panels.
1) Jack up the front of the car about 18 inches and secure with jack-stands.
1b) Remove the plastic panel under the car that you remove to access your oil filter. It has about thirty 10mm bolts securing it to the bottom of the car. Seriously, though, I think it's 10-12 bolts.
2) Remove the cold-air intake plenum from the top of the radiator. It is held on with two 10mm bolts.
3) Unplug the Mass air flow sensor. See the blue arrow in the pic below.
4) Remove the 10mm fastener for the air box, shown with red arrow at top right in the pic below.
5) Loosen the air intake hose clamp shown with a purple arrow in the pic below.
6) You will have to remove the air-intake box, so you will need to disconnect the MAF sensor wire from the MAF sensor in the air intake box. You have to cut the ty-rap to do this. See the green arrow in the pic below. It's really irritating that the ty-rap can't be replaced by a normal ty-rap. I still have to source the kind Infiniti uses. There are some on the electric fan assembly, too, as you will see in a sec.
7) Pull up on the air-box and remove it from the car. It is pushed down into two ball-and-socket fasteners at the bottom, but they just snap in and out. You should have the view in the pic below. The red arrow shows the A/C compressor.
8) You need to remove the serpentine belt. I'm sorry that I did not take a photo on how the do this, but it's really easy. The map of the belt route is in your owner's manual, or you can use this pic for it. Basically, you use the serpentine belt removal tool or a large ratchet/breaker-bar with a shallow 14mm socket and turn clockwise on the bolt-head shown with the green arrow in the pic below. This moves the tensioner clockwise and slackens the belt for removal.
9) Drink a beer.
10) Remove the 10mm bolt in the center of the A/C compressor clutch. See the red arrow in the pic above. This bolt secures the A/C compressor clutch plate to the shaft of the compressor. You may need a strap wrench of large set of pliers to hold the plate while removing this bolt. The pulley is separate from it, so leaving the serpentine belt on before removal of the bolt does not help.
11) Remove the A/C compressor clutch plate. It should just come right off, so be careful and tilt it upward when it comes clear of the compressor shaft. There are air gap washers in there that need to remain in there. Don't drop one and lose it or you'll have to go source one.
12) Now you have a view of the front of the A/C clutch "flywheel" or "serpentine pulley." Whatever it's really called. You'll see a snap ring on the front of it that secures the pulley to the body of the A/C compressor. Guess what, though. You can't get a pair of snap-ring pliers in there to get that off without taking the electric fan assembly out. Dammit.
13) Unplug the electric fans at the ballast, which is located between the two fans. See red arrow in pic below.
14) Also unplug the little grey connector at the top of the fan assembly that I forgot to take a picture of. It's right in the center, right by the hood latch. (NO PIC)
15) Separate the electric fan power wire completely from the electric fan assembly by cutting the 4-5 ty-raps that secure it to the fan assembly. See blue arrow in pic for one of them. These are more of those stupid ty-raps I need to source so that I can replace them.
16) At this point, you have a choice to make. You can either just disconnect the radiator hose at the top passenger side of the radiator, or you can drain the radiator first with the drain plug. It's up to you. I was already here, so I figured I would just replace all the coolant/distilled water mixture in the radiator, so I drained it. If you just unplug the top hose without draining the radiator, you'll only lose about half of a quart of coolant. You have to disconnect this hose to get clearance to get the fan assembly out.
17) Remove the two 10mm bolts that hold the fan assembly to the radiator. Sorry, forgot to take a pic before removal, but the red arrows show you where they were.
18) Get back under the front of the car and look at the bottom of the fan assembly. You'll see a hose that is tucked into a holder on the fan assembly. Move that hose out of the holder. Now you can lift the fan assembly out of the top of the car. Be careful not to contact the radiator when removing it. The picture above shows you what you should see after fan assembly removal. Now you have a little more room to work with at the face of the A/C compressor clutch.
19) Remove the snap ring that was pictured in #12. Use your fancy new snap-ring pliers. You will notice that you are pretty much rubbing the radiator with the handle of the snap ring pliers, so be very careful.
20) That snap ring is the only thing, theoretically, holding the pulley to the A/C compressor body, but if you live up North with the ice and salt, the pulley bearing might be held on with corrosion. For me, it came right off with a slight pry from the top and bottom. Be careful when prying on the pulley not to damage it.
21) With the pulley removed, you now have a view of the electromagnet. Follow the power wire to the connector on top of the compressor and disconnect it. This was a pain in the a** to get to. I forgot to take a pic of it because I was getting pissed at this point. Little did I know that I was about to find out what pissed really was. Below is a pic of the electromagnet, which is held to the body of the compressor by only a snap-ring. A very big, very hard-to-get-to, very hidden-from-sight, piece-of-s***, of a snap-ring. You will learn to hate it.
22) Remove the snap ring that secures the electromagnet to the compressor body. Sounds so simple, doesn't it? You'll notice first off that you can't actually see it because it is about an inch inside of the electromagnet body and you have no straight-on shot of the compressor because of the radiator. You could remove the radiator, but then you still have the condenser in the way, which you don't want to remove because the whole point of this is to not break into the A/C system. Put the largest tongs in your snap-ring pliers (the gold ones.) I duct-taped a small mirror to the radiator, but that didn't really help because once you get the pliers in there, the pliers get in the way of your sight, anyway. I'm not going to lie to you. I did this completely by feel. I had to walk away a couple of times. It took me 3 hours to get that damn snap ring out of there. When it finally came out, I almost cried.............and I'm a 44 year-old man. Do what you can and be careful not to puncture the radiator with the pliers, or your fist. I drank some beer.
23) The electromagnet falls off at this point and this is what you see. Notice where the red arrow is. There is a dimple on the electromagnet body that goes in that relief.
Once you get the snap-ring back on there to hold on the new magnet, that dimple and a little metal tab are all that keep the electromagnet from spinning with the pulley.
24) Drink two beers.
25) Put the new electromagnet on the compressor. Be sure to put the dimple from the new part in the relief shown above. I realize that the snap-ring is not all the way on in this picture. The picture is actually what made me realize this. I got it in there after I realized the magnet had some wiggle to it, which is BAD. See #24.
24) Once you get the snap-ring back on there (Not as much of a pain as removal) to hold on the new magnet, that dimple and a little metal tab are all that keep the electromagnet from spinning with the pulley. See both red arrows. The one on the right is the metal tab. That tab sits against the body of the compressor to keep the magnet from spinning. If you get the snap-ring on there and the electromagnet feel loose on the compressor, bend that metal tab toward the body of the compressor with a punch and hammer. If the electromagnet is loose, the pulley will contact it all the time and make a rattling noise. Worse than that, the pulley could technically grab the electromagnet hard enough to spin it around completely with it, which would break the power wire and possibly cause some serious damage to the A/C compressor and serpentine belt system. I don't know why Infiniti has the A/C on the main serpentine belt system. It should have it's own belt. Make sure the electromagnet does not wiggle very much at all after installation. That's the thing to remember.
25) Plug the electromagnet in. If you order this exact part, the wire will be about an inch too short to connect it in the stock location, so you can either extend the wire before installation or you can pull the stock plug on the harness-side from the holder on the compressor and just secure it somewhere else with a ty-rap, like I did.
26) Put the pulley back on with the snap-ring.
27) Put the clutch plate back on with the 10mm bolt. You might need the strap wrench or a very large set of pliers to hold the clutch while torqueing the bolt. I don't know what the torque spec is, but it's not much more than 5 ft/lbs, judging by how easy it was to remove.
28) Spin the pulley and make sure that spinning the pulley does not spin the clutch plate. If it does, you lost a gap washer, or you need to go source some. You keep putting in washers until the clutch plate has a gap between it and the pulley (flywheel.) It's called an "air gap." If the clutch plate spins with the pulley, it would basically mean your compressor was compressing Freon all the time, which would be bad if your A/C wasn't actually turned on. That would damage all kinds of stuff.
29) Put your fan assembly back in the re-attach the hose at the bottom in the holder on the fan assembly. Run your fan power wire back over to the ballast and plug it in. You just have to put regular ty-raps where you can until you source some of those stupid ones from Infiniti. Don't forget to plug in that little plug at the top of the fan assembly, too.
30) Re-attach the radiator hose.
31) Put the air-box, cold-air plenum, and under-motor plastic plate back on.
32) Plug in the MAF and tighten the intake tube hose clamp.
33) Turn on A/C and enjoy cold air, again.
34) Drink the rest of your beer, if you have any left.
Ilya
Great work! Linked this in the FAQ.
Sstupid
Thank you, sir!
LIBRILZ
Car: 1990 Nissan 300zx
2007 M45 Sport
Tackling this job atm, this has to be one of the worst things I've had to do on an automobile, and I've worked on a lot of stuff..Easily a 9/10 on frustration..it isn't going well lol
I'm having trouble mostly getting the second snap ring off..The Pliers I have do not open up enough..I tried some craftsman ones (different than in pic) and I've tried some brand from harbor freight which I will be returning to the store as they have not helped me..I'm going to check sears to see if they have the craftsman pliers pictured above..Also going to see what lowe's and a few other stores are selling..this job is horrible but it does help slightly to unbolt the a/c compressor so you can tilt it slightly and see the clip ring, it won't be easily visible still but it helps somewhat
Also the 6 pack of shiners is not optional
LIBRILZ
2007 M45 Sport
I did it, my A/c is working again!
Bought the Channel lock brand pliers from lowe's for the second clip ring, worked pretty well!
Sstupid
LIBRILZ wrote:
Tue Feb 12, 2019 4:30 pm
Awesome my man! Sorry, I know this job was a beotch. Glad to hear it worked out for you. Did you get your clutch off eBay?
LIBRILZ
2007 M45 Sport
Sstupid wrote:
Tue Feb 12, 2019 5:26 pm
Eh If I had to do it again I wouldn't want to but I would do it, what made it so hard was not having decent snap ring pliers, the second snap ring I removed with the Channellock brand of pliers sold at lowe's, and the first snap ring I took off with some smaller craftsman pliers, the 10mm bold that holds the clutch on I just used an impact to take it off and put back on..Not too tight as I was scared I could break that tiny bolt
Yep, same one as you, the 95 dollar one..I couldn't find any other source..
I find it funny it was 95 for our cars yet the same vendor sells other coils for like 25 dollars on other cars...oh well at least he sells a coil for our cars right?!
Side note, my coil had been on the way out since last april or so, it would cut off sometimes and not turn back on at all until hours had passed by or something, then in september it just outright stopped working..well hopefully that's all I gotta do a.c. wise for awhile :yesnod
Sstupid
Woot!!
eshieh
Car: 2008 Infiniti M35 S
Sstupid- not sure if I should thank you or curse you. You gave fair warning and made it seem difficult, but it was more difficult than I imagined. Was able to follow your instructions and my AC blows cold now, but was the biggest pain in the a**. Used ChannelLock c-clip pliers. Used LED mirror to see the second c-clip, but was the most frustrating, pain in the a** thing I have ever done. One tip for anyone attempting this is to rotate the second c-clip to about the 5 o'clock position on your first couple of tries then subsequent tries you will have a better view, as long as the radiator is out. The first time I put the second c-clip back in, it looked like it was in the groove but the coil was loose. So I used a punch to push the c-clip back more and it snapped in, making the coil much more secure. Used the ebay coil as well. Would not do again.
LIBRILZ
2007 M45 Sport
We have the M45, you have the M35 so things will be a little different..I would do it again..It's pretty easy now that I know what I' doing and have the right tools..might be harder on M35 though I don't see why a smaller engine with more room would make it harder...but it could..Anywho congrats
cheekymonkey
Car: 2007 M35X
Sstupid wrote:
Wed Sep 30, 2015 2:46 pm
Really awesome post dude. Much appreciated. I'm troubleshooting my A/C issues now and going through the process of elimination so I can pinpoint the source of the problem. Where is the 12v connector that you're referencing above? I see an electrical connection to the right of the compressor, is that it?
wingFeather
Car: Current: 05 G35 Coupe
Previous: M35, M35 Sport, cube, J30, s13 sr20det, s13 rb20det, s14 zenki
I'm here in 2024 to confirm that the final snap ring is indeed impossible to remove.
Not only that but the electromagnets available from parts places are different and do not have whatever these wires are (see photo).
Save your sanity and just purchase a whole new compressor.
upload photo image
