lenso wrote:Where can I get a set of the O-rings and seals?
The o-rings you can get at a parts store. They should have a box of different sizes you ca pick out of. As for the seal, I'm waiting on this company to e-mail me back I had looked through our catalogs at work and we can get a seal kit for every compressor but mine. Go figure.
NotDave wrote:so 'rebuilding' a compressor is just replacing the seals?
mine barely works and makes lots of noises (not from the belt)
how can you tell if its a mechanical failure?
It's probably just a bearing. You'd be better off just getting a reman'd compressor. Try to spin the compressor and feel for any rough spots. It's gonna feel like your turning your engine by hand. If there is a problem it might not spin all the way around but get stuck in a certain spot.
Arashi wrote:I've been without proper working A/C for quite a while and have been thinking about an overhaul to get it working again! My problem though is that it doesn't even engage, no light or anything... When I had something else done, I had a dealership take a look and just tell me what's wrong...
They said my A/C was just out of coolant or whatever and needed to be converted to be refilled, and that there wa a possibility that my compressor has a hole in it. How would I, following these steps, be able to tell if my compressor is even -working-?
If you look at my second picture, on the right hand side of the compressor, you'll see a sensor. Thats the pressure sensor. It senses if you have pressure inside the compressor and if it senses no or too little pressure it won't engage the clutch. It does that so you don't fry your compressor. Cause w/out freon, there's no way for the oil in the system to coat the moving parts. And I'm sure you know what happens to your engine w/out oil. It's the same w/ compressors. The best way to go about your problem is to just buy a retrofit kit (at your local parts store) for like $30. It comes with the R134A fittings that you just screw onto your existing R-12 fittins, 3 cans of R134a (which you'll probably only use like 2), the pressure gauge, and a step-by-step cd for your computer. When you "charge" your a/c, do it with the car running and the a/c on full blast (recurc too). The sensor should detect pressure and engage the clutch. Just fill to the propper pressure and enjoy cold a/c. If you hane a leak you will find traces of "oil" near the leak. The oil will look clear and it doesn't smell like motor oil. Kinda musty. Thats how I found my leak.
180sxfaktory wrote:Outstanding How-to!
240sxvaj wrote:NICE!
Thanks!
