Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Fri Oct 25, 2002 8:18 am
This is what I got from my local Infiniti dealership:
TECHNICAL BULLETIN ITB93-068
J30/G20/Q45 Remote Transmitter Programming
Applied Models: 1993-94 J30; 1993.5 G20; 1994 Q45
SERVICE INFORMATION:
The proper procedure for programming additional remote controllers is listed below.
SERVICE PROCEDURE:
While sitting inside the vehicle:
1. Open the trunk.2. Close and lock all doors.3. Insert and remove the key from the ignition six (6) times within ten (10) seconds.4. Manually unlock and lock the driver’s door once (1) to enable “setting” mode.5. Push the lock button on the new remote controller once (1), just long enough to hear it beep, within five (5) seconds of completing step 4.6. If additional remotes are needed (up to 3), repeat steps 4 and 5 for each additional remote immediately after programming the first remote.
Note: A total of four (4) remotes can be programmed to function on the same vehicle.
For additional information, please refer to page BF-38 of the 1993 and 1994 J30 Service Manuals; page BF-17 of the 1993 G20 Service Manual Supplement; and page EL-148 of the 1994 Q45 Service Manual.
The procedure may be different for different years.
Call the parts guy at your local dealership.
He will need the Serial number of your car, and the FCC code off the back of the remote. You may not have the right remote.
