so I kinda borrowed the title form Rob Zombie, anyhow my car is about to get a complete rebuild soI figured I'd sharestarting at the beginning, I picked up the car in St Louis back in 2003 (I paid $1000 for it in it's non running condition, stuck carbs and clogged rusted fuel tank were the major issues)I ran it in the GRM $2003 challange 1 month after draging it homeI returned that car to the challange a few more times finnishing 10th overall in $2005, the car continues to evolve to get to where it is todaya quick list of mods:L28ET T3O4E 57 trimMegasquirt N Spark
http://www.diyautotune.com/cat....htmlMSD Blaster 2 CoilNissan Motorsport plug wires455 cc DSM injectorsPallnet O ring fuel rail
http://www.freewebs.com/pallnet/Aeromotive RR FPRTreadstone vertical flow intercoolerhttp://www.treadstoneperforman...oolerTial BOVMetal HGARP headstudsNissan Motorsports Euro Damper17x11 front and 17x12 rear CCW wheels
http://www.ccwheel.com/files/w...assicsectioned 280Z strut housings
zerothread?id=237090GC Coil overs 440 lb/in front, 350 lb/in rearhttp://www.ground-control-stor...CA=27Tokiko Illumina inserts intended for an MR2, BZ3099 front and BZ3015 rearMSA swap bars front and rearTechno Toy Tuning camber plateshttp://technotoytuning.com/productdetail.php?p=648 Techno Toy Tuning TC rodshttp://technotoytuning.com/productdetail.php?p=668Nissan Motorsport Quicksteer knucklesJSK Willwood adapters
http://www.jskinnovations.com/datsun.htmWillwood superlite 4 pistons front and rear12.18 vented rotors front and rearSumped stock fuel tankMSD fuel pumpZ specialties1 wire alternator
http://www.datsunstore.com/pro...28564odyssey 680 13 lb battery located behind the passanger seatCorbeau GTS2 seatsPeak 5 point harnessesGrant 14" Steering wheeland adapter280ZX Trubo T5 transcustom driveshaft form Republic DieselCompetition Clutches Stage 4 clutchhttp://www.competitionclutch.c...=3272Fidanza Flywheel
http://www.ultrarev.com88 Z31 Turbo 3.7:1 CLSDZ31 Turbo CV chafts (flipped the tuip)Modern Motorsports biltit cv shaft adapter companion flanges http://www.modern-motorsports....id=46B&M short throw shifterRon Tyler Diff Mountscirocco style dual electric fan
so I rebuilt my engine nd decided to tackle some rust repair while the engien was out, the swap bar mounts were in really bad shapeI rebuilt them using stiffer bracing and moved the moutning nuts further apart to accomodate my larger bar wthout the need of adapter plates
unfortunatley the more rust I fixed the more I found, and after some soul searching i decided it was time to take the chassis bare and rebuild it for the ground up, I'll be updating this thread as I go so keep an eye on it, step 1 is to stript he chassis bare and put it on a rotisserie, I'll update with pic's once thats done, then it's off to the blaster
