Hey guys I just finally got a RB bracket and brand new RB pump for free.
Converted a friends RB25 harness for his S13, that was the payment. WIN!
Annnyywaysss. Ive never had power steering in the car since I swapped it. The KA pump with the lines has just been chillin on the subframe connector.
So today I bolted up the RB bracket with the RB pump to the block.
So far I noticed I need to get a longer rubber hose that goes from the underside of the power steering reservoir to the pump.
And then I just gotta get the KA line off the KA pump.
Now my question is, when I finish this up tomorrow, my idea was to take the KA pump line, and only use the fitting that has the banjo bolt, and remove the one where it has the nut, and then just thread the banjo bolt through the line and into the RB pump.
Is this how everyone does it?
By the way this is a RB25 series 1 into a 95 S14.
Also, I dont have the power steering idle bump wired in, so is that going to cause any problems when I go full lock at idle/cruise?
Thanks for the help!!!
