bulld0g »
https://forums.nicoclub.com/bulld0g-u63635.html
Sat Feb 02, 2008 9:36 am
How To Install Lowering Springs
New Springs
The tools you will need a 17mm is also used for the rear. Start by jacking up the rear of the car and install the jack stands forward of the rear axle.
This is what the stock rear look like in the air.
Insure to place the floor jack underneath the axle and elevate to take the pressure of the the shock and springs
Remove the lower shock bolts on the drive and passenger side shocks using a 17mm socket.
After both bolts are removed lower the floor jack slowly so that you can remove the stock springs.
Replace the stock springs with the new ones and insure that you rotate them into the spring cup Raise the floor jack and reinstall the lower shock bolts, then raise jack high enough to remove jack stands and then lower car slowly….remove jack.
And here is the Before shotAfter
Now For the Front springs….
Jack up the front of the car place the jack stands as far forward behind the wheel wells you can. Remove wheels and this is what you should be seeing.
Remove this nut and bolt…you may need a breaker bar to get them free
Release the brake line clip using a screw driver or some pliers, be careful not to gouge the brake line
Next remove this nut and slide the bolt out…
This is what you should be looking at now
having a someone help would be good to hold the strut so is doesn’t fall… Remove the top three strut bolts…and remove the strut.
Compress the spring with a spring compressor (or you can take them to a shop for about $30-$40) remove the top strut nut and remove the cap…..remove spring replace with new spring, compress new spring reinstall strut cap and bolt and tighten release compressors, reinstall strut in reverse order of removal.
Front springs installed
Repeat for opposite side.
Finished product
Before After
I hope this helps out all of those that are mechanically inclined would like to do this install themselves.....It took about an hour and a half from start to finish...I would recomend getting an allignment too....Good Luck
Modified by bulld0g at 6:27 PM 2/2/2008
