So I finally get around to making this little how-to on the HID's. Sorry guys for taking so long and thanks for your patience. I had to redo the wiring on the ballasts and now they're up and running. I posted pics of the finished product in another thread (an end to the HID saga) so check them out.
X-Light H11 5000K
First, always disconnect the negative terminal of the battery when working with power
Remove wheels. Always chock your back tires for safety.
Underneath the bumper, there are 3 screws on each side which need to be removed. Not the clips, just the screws.
Inside the well, you'll find about 8-9 clips that have to be removed. Remove by using flathead screwdriver and wedging the pins up, once exposed, pull out.
Carefully pull out wheel lining (2 pieces) exposing the space behind the headlight housing.
This is what you'll see at this point.
Remove stock bulb by disconnecting harness and twisting counter-clockwise, making sure NOT to touch the bulb in case you need to use it again.
Put new HID bulb in place by inserting and twisting clockwise until it locks in place.
Connect harness to new bulb.
Now connect bulbs to ballasts.
Find a place to mount the ballasts.
At this point I was rushing because the rain started coming again. I forgot to take a pic of my mount point on the passenger side. I used two existing holes in the frame where I ran wire ties through. Tied the mounting plate against the frame and that was it. The pic above is where I mounted the driver's side. It's on the frame also; I just used ties. Thought about drilling holes to mount is solidly, but the rain was coming down so I rushed and just tied it. Don't mind the messy wires. I just took a pic of where I was mounting, then I cleaned it up with ties.
Just reverse the process with the shield, clips and screws. After putting everything back, mount wheel and lower the car. Reconnect the battery terminal and there you go
Well, that's about it. Easy, huh? Again, sorry I took so long to make this how-to. I hope it'll help some of you guys out. I just wanted to do this because I believe it is the quickest, easiest way to install HID's on the Alitima. I took my bumper apart last week, but this just goes to show you that it isn't necessary. Let me know if you have any questions.
-eric
*edit: Just a couple of pics so you can see the finished product.
Passenger side with HID and driver side with stock bulb. Just to show you guys the difference in color between the two. Can't really tell because it was broad daylight, but just to give you an idea.
Diamond white
The lights are blue for the first 15-20 seconds after firing up. Then they brighten to a nice white.
Bad timing I guess. After I moved back from LA, I would visit there every single month. The reason I came back home is because I got homesick. And now I miss LA. Kind of wish I never left
Oh well, everything happens for a reason, right?
