robpctech1 »
https://forums.nicoclub.com/robpctech1-u207841.html
Mon Aug 06, 2012 11:54 pm
I know on some M models you can go to the Diagnostic Screen and some have the SAT option. Not sure if it will tell you the ID there. (Mine doesn't have the SAT diagnostic option) FYI to get to the Diagnostic screen, Turn the car on (turn the radio off if its on) push and hold the settings button and Turn the Radio Volume button clockwise (or Counter clockwise) about 40 clicks. WARNING I wouldn't mess or change things there unless you know what you are doing.
But as a side note in the Diagnostics Option is where you can change the Bluetooth ID and Passcode if needed. I've Had Multiple Ms and other cars with the same Bluetooth id which is why I changed mine.
