Chris92SE »
https://forums.nicoclub.com/chris92se-u42786.html
Sat Sep 15, 2007 6:50 pm
If you aren't sure about some of these parts, like the MAF sensor, you might want to try picking up a used one cheap to see if that is the problem. Almost $500 is very steep, probably 1/5 or 1/4 the value of your entire car.
On you can usually find one for under $50 shipped. They are all the same on 3rd gens, 89-94 regardless of engine. Yes, it will be used, but the cost is so much less, it's worth a try, at least to me.
I would also recommend checking for ECU codes, but one of the crappy things about OBD1 cars is they don't seem to want to throw codes very often. Of all the problems I have had over the years, I can only remember one code for the coolant temp sensor.
As for the coil packs, I can't recall anyone ever having a problem with ones bought from a parts store like NAPA, Autozone, etc. I would just start calling around and finding the best deal.
CHRIS, PLEASE DON'T LINK TO COMPETING FORUMS.
