240DrpTop »
https://forums.nicoclub.com/240drptop-u75116.html
Sun Dec 16, 2007 1:06 am
Lrgfreak47,your fuel pump is located in the fuel tank, you can access your fuel pump through your trunk. Go to tech pages,air intake and fuel delivery,s13 installing walbro fuel pump.This should help. Make sure you disconnect your neg.battery cable before starting your removal,don't need any sparks around that open tank.Good Luck!By the way this would be a good time to check that fuel filter, if you haven't done that yet.
