SilverTwin(OH) »
https://forums.nicoclub.com/silvertwin-oh-u29397.html
Mon Jan 05, 2009 4:48 pm
The hood latch can be adjusted down, there's three 12mm bolts on the latch. Loosen them and slide the latch down a little at a time. If you adjust it too much and put too much tension it, the hood will not reopen.
If your hood is more the 3/16" or so out of adjustment, odds are that the car has been jacked up improperly. If the car is jacked up by the core support, it will not hold the weight of the car and will bend up which also moves the upper core support that the hood latch is attached to, this results in the hood being high even when the latch is bottomed out. Look under the car for damage on the core support directly in front of the radiator, it is typically obvious as it should be completely flat.
**Edit**
In the photo, it appears as though the hoods aligns properly with the fenders. If that is the case, all you need to do is shim the center panel up a little.
