yodawill2000 wrote:Excellent write up G !!Was the evaporator assembly easy to clean out ??Ive heard they get nasty over the years.
I had a leak in the coil, when the new coil arrived it had the wrong size fittingssent that one back and that is when the 95 had the oil leak/pressure issue. I have not had time to get to the oil pump yet. she sits on jack stands dead in the garage, Low oil pressure and no evap coil . That oil thing is all in another thread
The coil was actually easy to get out, once the system was evacuated you break the 2 lines loose that are under the hood, removed 4 mount screws and a few items out of the way and it just pulled right out. the bottom 1/4 of the coil was yuk and clogged with crud and that is where the hole was. 180K all in Florida so the AC was on 99% of the time.
Modified by Gerardjg at 4:25 PM 3/23/2010
