How To: 2011+ M37x Front Strut Bar Install (Cusco), DIY
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
This is my write up of how to install Cusco (or other) front strut bar on a 2011 or newer Infiniti M37.
The purpose of this write up is to provide helpful knowledge to anyone who may be attempting to install a strut bar on the M37. Specifically I own a 2012 M37x and installed Cusco strut bar part number 288 540 A (G35 07-08 Sedan, G37 09-14 Sedan, G37 08-13 Coupe, Q60 14-15 Coupe, EX35). While I own the AWD model, this may also be quite useful to rear drive M37 owners. I am not a professional mechanic but I've done this on several cars over the years and I love to do what I can on my own. Enjoy.
The bar was listed on Amazon here for $185 and my super awesome girlfriend got it for me for Christmas. :woot:
Safety check, parking brake on, flat surface bla bla bla...
You'll need a socket size 12mm and 2 extensions or 1 really long extension to properly reach and remove the nut closest to the firewall. Remove all 3 nuts on the strut tower and the black spacer/washer. Clean the area and fit the new bracket. This is the only semi-tough part on the drivers side; it's a super tight fit under the brake line and needs to be gently lifted up the get the bracket in place. Once it's in place there's no problem.
The passenger side is a piece of cake. Just push the bundled wires off to the side and/or pop the tab out to give yourself more space and fit the new bracket.
Once your new brackets are in place hand tighten the new nuts the came with the bar to ensure fitment and alignment. You'll need a 19mm socket for the new nuts. Make sure these are tightened properly before moving on as you will not be able to reach them after the bar is in place.
Loosely fit your bar on both sides.
Next slide the bolt through the bar and put the washer, spring washer and rounded nut on. Hand tighten both sides and then you will need a 17mm socket and a 8mm hex key to finish the job. Peel the protective blue wrapper off and enjoy.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Sorry in advance M56/V8 guys; I have no idea if this will clear your engine. :gotme
Ilya
It won't, :(
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Nice write up... time to add these to the line up... now there are 2 bars that fit the M37.
Ilya
RED_DET wrote:Nice write up... time to add these to the line up... now there are 2 bars that fit the M37.
Pull some vendor favors in and get some made for the V8! lol
Debonair
Car: 2011 Infiniti M56
wideopn11 wrote:This is the only semi-tough part on the drivers side; it's a super tight fit under the brake line and needs to be gently lifted up the get the bracket in place. Once it's in place there's no problem.
That looks like they are contacting. if so, or even if they are just very close, you might want to clearance the Cusco bracket a bit.
Ilya
Just put some foam there or something, done and done.
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
Actually 3: the tanabe, the cusco, and the GT spec (if you can find it)
RED_DET
Vendor
2011 Infiniti G37x
GTSPEC has been discontinued...
RED_DET
Vendor
2011 Infiniti G37x
Just FYI, I have (2) bars in stock and (1) that has been powder coated gloss black with the standard blue brackets.
Mjkkb2
Car: 2018 Infiniti QX60 AWD
2011 Infiniti M37S
2011 Nissan Quest
2001 Infiniti I30t(sold)
I just got the GTspec like 2 weeks ago from zspeedperformance.com
Btw, Cusco looks awesome, good write up.
Carson_hu
Car: 2008 Infiniti EX35
Do you know where to buy this nut? My car is EX35, I also have a tower ber like this, but it does not have its own nut, I am looking for some nuts. Or you can give them the size of them. thank you.
Malbec 56 Beast
Car: 2013 Infiniti M66xS Totaled 4/11/20
What's next???
2010 Subaru Legacy
1983 Porsche 928 S Euro (Sold) 2/17/20
I'd call the manufacturer and see if they can send you one or at least give you the thread size pitch.
Or take it to a hardware store and check fitment
Hope that helps you
Andy
ArmedAviator
I installed the Cusco bar a few weeks ago.
It looks good. I'm not too thrilled about the driver's side brake line fitment issue. I have a piece of felt wedged between the brake line and the bracket to prevent damage.
To be honest, I see no difference in handling. The bar flexes wuite a bit actually, or else I would not have been able to make it fit. I easily flexed the bar to get the the second bolt in the bracket. If it is to change handling by any measure, it needs to be stiff tube and welded-on brackets. I wasn't really expecting much if any habdling change, just wanted some bling.
