Q45tech wrote:Just because someone doesn't feel the need to add between 5k intervals doesn't mean it hasn't used some.
A good point.
Q45tech wrote:From my experience 90% of vehicle ownes don't even know HOW [exact correct method] to measure oil level.
Okay, here is what I do to get consistent measurements and fills, etc. Can you comment on it, please, Dennis?
1. When the oil is changed, HOT after engine shutdown, I make sure to get the place to remove the filter and plug and drain the oil for a minimum of 10 minutes, preferably 20, before refilling. I have them rotate or balance tires, or something else, while waiting.
2. I have them add 5 7/8 to 6 qts of oil at the refill. When I measure (next morning, as described below), the oil is usually just at the 3/4 mark (i.e., above mid-way) between MIN and MAX, and occasionally just above that.
3. I then measure oil level every other week as follows: Cold engine, car is sitting in my garage, level ground, overnight and has not been turned on at all. Take the dipstick out, wipe clean, insert, wait 10 seconds, take out and read the level.
4. If the oil reading is below the mid-way mark between MIN and MAX (I never let it get below the MIN mark), I usually add 1/4 to 1/3 qt of oil, rarely 1/2 qt (if it is at the 1/4 mark between MIN and MAX).
5. And, then re-measure the next morning: cold engine, ... etc.,
Usually, I only have to add some oil like this once between changes ... at about the 1700 to 2000 mile period. The next time it gets near the mid-way mark - generally near the 3750 mile period - I change the oil anyway, so adding some does not make sense!
This, I feel, gives me the most consistent readings, although I suppose that there always some differences due to general weather temperatures, etc. This is minimized though because the temperature inside my garage does not very as much as outside temps.
Comments?
Z
