try the Z32 Automatic, or look for a ford C4 Trans.....speeddocsson wrote:I am in the final stages of finishing a turbo vg30 swap into a m30. Apparently the stock transmission did not like the amount of horse power the engine was making and went to crap. I still want to put a automatic in the car because it will be mostly used for dragracing. If I get a stock z31 turbo (automatic) transmission would I have problems with it breaking? (The motor is making roughly 450 to 500 hp). Thanks for the help.
Yeah....i just noticed that my bad.....you guys have still been allot of help i appreciate it.JDMZ32 wrote:FYI, wrong forum. try Classic Z.
easy? it's not easy, it's all custom fab workspeeddocsson wrote:ILL GET SOME PICS.....How easy is it to put a power glide in? is it a close match up to original space in the frame....like will i have to screw with the interior?
it's fine lol, just pointing it out so you can post where you'll likely get even more help.speeddocsson wrote:
I blew up the stock T5 with only 250rwhp. I replaced it with the R30A. But I've seen a few people with 400hp and more running the NA transmission and not having them break.evildky wrote:I disagree wiht the popular theory on the Z31 5 speeds, the T5 is a good tranny and can take about as much abuse as the n/a trans, both are known to fail somewhere north of 400 whp, the 87.5-89 R30A can take the beating but they are kinda rare and basicallyt he same as the Z32 n/a trans which is more common
Birk's profile is set to private. This user must add you as a friend to see his/her photos.speeddocsson wrote:Ok so here are some pics of my car hope they work........
http://viewmorepics.myspace.co...52481
my bad here are the pics.........AZ-ZBum wrote:Birk's profile is set to private. This user must add you as a friend to see his/her photos.
If you want an automatic, the Level 10 upgrade is your best option.
The transmission the 240SX uses is the same transmission the NA Z31s use. The ONLY difference is the front bell housing.speeddocsson wrote:Us guys should get a medal, all the 240 guys have to do is go find one of the thousands of trannys we got it hard man....haha.
so should the R30A be able to take the abuse?
I blew the synchros for 2nd and 3rd gears as soon as I turned up the boost. After a transmission rebuild, it wasn't long before it wouldn't shift into 5th gear. Couldn't have been a linkage issue since it would go into reverse without any problems, although I never bothered to find out for sure. Found an R30A cheap enough after that.evildky wrote:there are many versions of the T5, ford and gm both used both world class and non world calss versions, the s130 and z31 were both non world class but were alo quite different from one another, imput shfts, output shafts, bellhousings shifter mounts and gear ratios all differ with model, the WC got larger bearings and shafts
the Z31 T5 imput shaft is longer than the S130 version also the lay gear tooth count is different which si a part of the imput shaft which means the companion gear should also need to be changed, it does appear that the static diameter of the Z31 T5 imput shaft is a touch smaller than the S130 and with the additional length might be a bit weaker than the S130 counterpart
Zbum, what is the procalimed weakpoint of the Z31 T5? just trying to figure if it's the imput or the output? I am quite sure the internal bearings and supports of the T5 are superior to the w71 series trannies
it just seems to be one of those regurgitated things, everyone says the w71 is stronger but no-one seems to know what the weak point of the T5 is
