Below is a tire test I conducted for SCCA members. Take note of the data logging screenshots provided and run deltas. Also, take note, that BF Goodrich Rivals (while considerably slower than an r-compound) are about 10 times better than the tires I see on most tuner's cars.
Some backstory on why this test was conducted:
-The SEB (Solo Events Board) passed a proposal that would remove r-compound tires (tires below 140 treadwear) from stock competition and create a new class division called "street" which would be basically "Stock" only with 140+ (and 200+ in 2015 and beyond) treadwear tires.
-Myself and a large number of National competitors hated this idea, as it makes our cars significantly worse to drive.
-Three National Champions and I ran my car on both A6's and street tires to get a delta from high level competitors and to get hard data from my traqmate.
B-Street vs A-Stock Corvette Analysis
Car:
-99 Corvette FRC
-46,000ish Miles
-Koni Single Adjustables
-33mm FSB
-Ferodo Pads
-Magnaflow x-pipe and axleback
Tires:
BF Goodrich Rivals (sticker)
-255/17 Front (32 PSI)
-275/18 Rear (28 PSI)
Hoosier A6's (35 runs before this test)
-295/17 Front (31 PSI)
-315/18 Rear (31 PSI)
Drivers (Alphabetically):
-Cormier (National Champion)
-Junior (multi-time National Champion)
-Newman
-Strano (multi-time National Champion)
Introduction:
As you can see, I'm easily the one with the least amount of accolades than my co-drivers in this endeavor (no championships, never even trophied at a Pro Solo), my cohorts have red jacket(s plural in some cases) to keep them warm in the winter, I have a long wool coat from Express. I'm also the one with the least amount of experience, as this is only my third year of autocrossing nationally and my very first year in a car. I'm bringing this up because this really makes me the "Average Joe" here, Mr. Mediocrity if you will. Since the whole justification for the "Street" classes is for your average/new competitor, I think I'm right up that alley (heck, I'm a downright n00b on street tires, I've driven on them maybe 5 times total in the past three years including this test), as nobody looks at a grid sheet and goes, "Oh, James Newman is registered, I'm screwed". My impressions of the vehicle and it's handling characteristics are what the SEB is concerned about, if their word is gospel.
To save time, I'm not going to go over our R-Comp runs, you don't need to read about how good an A-Stock car is, you just need to drive one once to find out.
The Rivals Test:
I was in charge of running/conducting the test and I thought it would be best if we did it Nationals style, meaning all four of us present, we take one run, come back, re-prep the car, put the next driver in, they make a run, come back, prep the car, put the next driver in, and so forth. While it's no mystery that both Sam and myself are not big on the idea of street tires on Corvettes, all four of us are competitors and performing this test in a competitive atmosphere like such made us all want to drive to the best of our abilities. Any notion of sandbagging to get false data from the tires can be thrown right into the garbage, Sam himself set the best time on the street tires.
Given that everyone says the Rivals get better and better with heat, I didn't put the car on a clock, the only times we halted the car were when coolant temps were getting high (Vettes get toasty, that's why you see the hood up on all of them in grid). We averaged about a run every 3 minutes going off my data loggers times. I wanted to give the tires every advantage they could get.
Sam and I set our fastest runs on the first run. Junior and Cort set theirs on their second runs respectively.
Rivals Debrief:
The infomercial for Rivals we all saw with folks talking about it handles like an R-Comp, I disagree with. The handling is nothing like an R-Comp (maybe on smaller cars this is true, but on mine it is not), I'm very familiar with what my car is capable of on A6's, this felt nothing like it. The grip wasn't bad laterally (we pulled 1+ G) by any means, but the way the tire reports the grip is completely different. I never really trusted the car (especially transitionally) and dropped it on my final run (I dropped it on my final run on A6's but that was because I was in the dirt, it was very sandy).
Going into this test with the popular opinion being that the Rivals get better with more and more heat, I drove my first run at 8/10ths to get a feel for what the car is like. I then mentally factored in that the tire is going to be better my next run and ramped it up. The tire felt the same, no better, no worse, and the things I was demanding of the tire translated into overdriving in this case. A6's come to life with each run, the Rivals pretty much stayed the same (nothing wrong with a consistent tire, its better than one that falls off). Had I known that the car would not have more grip my second run, my approach would have been very different.
Junior brought up a good point, we never adjusted the car for the street tires, and this is true. Perhaps the car could have been better, perhaps worse. Things like this take time, money and effort. This was one of the things that was mentioned in the "saving money" sales point of street tires in stock, but the amount of testing to get a full tilt "Street" class car is going to take a lot of work and a lot of time, this translates into a lot of money being spent, not saved. Talking with Borg at Spring Nationals, he mentioned he was going to try B-Street and I wish him the best of luck.
THE GOOD
-Car isn't terrible at all. If all I knew was street tires, I'd be one of the folks going "Whats the big deal with changing/getting rid of Stock"?
-You can see the friction circles for each of us, they look very similar between Rivals and A6's. As I stated before, the lateral grip wasn't bad in sweepers, I didn't quite trust it in transitions but sweeping was fine.
-Honestly, the way I ran it, I became entertained with the competition and half way through blocked out that the car was on street tires. I like competition and it was fun. While not for me, I can see the appeal for it certainly.
THE BAD
-Sam nailed it, the problem is longitudinal grip. Going off the data, the cars aren't losing much time at all in corners, it's mostly in the entrance and exits. Braking and accelerating is where the biggest problem areas are.
-Safety. During our Rivals runs, there was some concern over how hard my car was being driven. Now, I fully appreciate it anytime someone treats my car with respect and I was thankful that they were being so, but I told them that I trusted them and they should go 10/10ths. Now, when the r-comp runs came, there were no issues driving my car to the limit.
-TIRE WEAR! These were sticker tires and we took 15 runs (12 competition runs, 3 scrub in by Danny) on the tires and I drove home from the site on them (115 miles). Danny estimates that we lost about 1/32nd of tread. This may seem bad or good to some people, I really don't know as I don't know tire life well on street tires, but what is alarming is that all five of the people that drove the car are experienced Corvette drivers and know how to drive with the rear, meaning we all know how to make tires last. Someone much less experienced (ie: your novices the SEB is trying to tell that tire wear wont be a problem) is going to have MUCH worse tire wear because they will not have the skillset yet developed and will most likely be driving with the front still.
Conclusion:
It was an eye opening experience and great driving with three people I enjoy being around and learning from. I definitely learned that the car isn't horrible, which was my biggest fear. Like I said in my "THE GOOD" notes, if all I knew was street tires, I think it might be an enjoyable vehicle. Can it compete with S2000's in BS? Maybe, I'm a bit more hopeful now after driving it on street tires.
Brief touch on STU:
I think anyone who is afraid of C5's in STU should put their fears to bed, it's going to take a lot of work to get them up to the speed they need to run (again, it wasn't as bad as I thought it would be, but it wasn't as good as the masses feared). Could it be a good STU car? Perhaps, but in a pro it's going to have a huge disadvantage, giving up .4+ on each side to an AWD launch. STU's pax is .846, A-Stocks pax is .847, so we run similar times. If you compare the Rivals runs to our A6's runs, that's a lot of time to make up.
FWIW, the day before this test, Junior and Courtney were running the SSP C6Z on 335 Rivals (well past the point of STU prep) and couldn't match the times Sam and I put down in my A-Stock car on bald A6's (that most likely had about 70-75 runs on them before I drove 800 miles on them for fun and then did a school on them) in 1/3rd of the runs they took. This was also on a course that had a monster straight on it, plenty of room to gallop. Again, considering that STU needs to run near AS's times, they were still off in a rocket ship with huge street tires on it that is prepped well beyond STU levels.
Videos:
RIVALS
Strano 46.346
http://youtu.be/Yv77_X833LQ
Cormier 46.684
http://youtu.be/EYAAlzE_sl4
Junior 46.753
http://youtu.be/A5QG9Vg2juQ
Newman 47.684
http://youtu.be/BwoDUoCtXUg
A6'S
Strano 44.188
http://youtu.be/ICQ9-a2-Z_A
Junior 44.371
http://youtu.be/dBUay1CD0Us
Newman 44.701
http://youtu.be/KT-VoCSRQ0Q
NOTE: IF YOU WANT THE TRAQMATE FILE, LET ME KNOW, I WILL GLADLY DISTRIBUTE IT!
Data logging screenshots of the sectors of the course
