Doesn't matter, putting the car in park wont do **** for holding the engine still anyways LOL remember, you have a torque converter, not a clutch. This is why your engine will run while it is in park and in drive LOLQ451990 wrote:The typical method is to use a chain wrench wrapped around the pulley with some sort of protection (old belt) to keep from damaging the ribs - and brace it against something solid... like those crossmembers that run at a 45 degree angle. I certainly wouldn't use the parking pawl in the transmission to hold up to that kind of torque!
Heath
Funny you ask that. Just this last Friday I had to take a length of about 3.5' of pipe, weld an 1/8" plate to the end of it, drill a 2" hole in the center of that plate to leave room to get a socket on the bolt. Drilled four more holes that line up with the holes that hold one of the extra pulleys, bolted it up, rested it on the ground and used a breaker bar to pop the bolt loose. BUT, this was on my Toyota 4runner. The Q45 only has the center bolt that hold the pulley on. No other bolts in the face of it.captainluigi wrote:am wondering how many of us own or have access to a 9'' o.d. chain wrench. i bet someone has come up with an effective alternative. i will get a loaner 300'lb. snap-on torque wrench manana. who has gone the path of crank pulley replacement before? what did you use to hold crankshaft?
Yes, I am serious. Like I said, I will probably catch **** for it, but it works. Have you ever bumped a starter before to turn an engine? If you just tap it, it doesn't spin but a couple degrees.Drake57 wrote:Surely you're not serious about bumping the starter. Sounds like a sure recipe for disaster.
Actually acheiving 270 ft-lbs is quite difficult for DIY mechanics. Are there any pneumatic driven impact wrenches capable of 270 ft lb with any way to be able to accurately reach that torque without over torque?
A few weeks ago I helped my son remove his crankshaft pulley from 1991 Q45 - I used one of the serpentine belts looped around the pulley, then put a lag bolt into a white pine 2x4 on edge to hold the other end of the loop - in effect a chain wrench. This served to remove the bolt no problem, although it likely was not torqued to factory spec, as this engine already had chain guide upgrade.
My question is: Is it safe to torque to spec using chain wrench or the like, expecting the pulley (that is attached to pulley hub with rubber) to be able to withstand that kind of torque?
The possible consequences of the bolt coming loose during operation are obviously many and severe. Was the mention of loss of oil pressure a generalization or is there a specific failure mode?
Thanks, Drake
Bought mine today at Harbor Freight for $20. 24" aluminum handle which now has a very slight bend. Wrapped a leater belt around the pulley so it was double where the jaw of the chain wrench touched the pulley.captainluigi wrote:am wondering how many of us own or have access to a 9'' o.d. chain wrench.
What about shoulder rehab. Mine is killing me.Q45tech wrote:Depending on arm strength [we have a complete gym at T3] you may have to adapt torque wrench with extension pipe.
Too little like 180-240 lb/ft can cause serious oil pressure problem!!!!!!!!!!!!
