evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Oct 22, 2008 6:07 pm
unbolt it? it's kinda tricky to get to but it's just that simple, there might be some accessories int he way but getting to it is the most difficult part
disconnect negetive battery cable
loosen the adjuster bolt at the bottom ear of the alternator
back off the adjuster nut that is perpendicular to it
looster the front and rear pivot bolts
remove the belt
remove the both pivot and the adjuster bolts
unplug the wire harness on the back of the alternator and unbolt the ground and power leads on the alternator
reverse order to install new one
