bimrtech wrote:The sprocket will pull off, may need a little help with a flat head, but most just pull of with your fingers. Then take the oil pump off. You do not need a gear puller for this sprocket. The one you have is for a pressed on gear like on a small block chevy.
When you took the pistons out, did you make triple sure that the studs on the rods did not come in contact with the crank journals or the cylinder walls? Use fuel hose over the studs to help in assembly and removal.
BS!i've have never, or even heard of anyone pulling that sprocket off by hand.
I got mine buy making a simple tool.
1. buy a pitman arm puller.2. grind the arms thin to fit behind the gear.3. remove thrust bearing for more clearance.4. pull gear off.
other than that, you'll have to cut it off.
