Victor »
https://forums.nicoclub.com/victor-u94029.html
Sat Nov 01, 2008 12:59 pm
Success at last. I managed to get the bent power steering belt tension adjustment bolt out and staightened it out by pounding it with a mallet. Then I managed to pry the power steering belt off so I could replace the alternator/water pump belt which was the reason I originally started this ordeal. I then pried the old power steering belt back on and what should I find is its now slack, evidently all the pounding I did on the power steering pump did move it a tiny bit. So with the now straightened adjustment bolt I was able to tighten it up. So now everything works. I called an Infiniti dealer to find what they wanted to change the three belts, they wanted two hours labor at $145 an hour, plus the belts which would have been more than an auto parts store charges. If I didn't run into the power steering pump problem, and knowing what I know now, I probably could have done the job in three hours, instead it took me two days, because I ended up taking off the air intake plumbing, radiator hoses with the associated mess, the fan, and the lower fan shroud, and the battery.Some hints. You can take the fan off by removing the four 10MM bolts holding it on. It slips out from the top. The adjusters all take a 12MM wrench, one of these gear wrenches works really well for this purpose. You have to loosen the nut on the idler pulley shaft to adjust it. I was able to do the job using my ramps which only raise the front end of the car about six inches. Loosen the pivot nut for the alternator using a 17mm wrench when adjusting it. The lower part of the fan shroud is removable, there are some plastic tabs holding it in place.
