Trumpkin »
https://forums.nicoclub.com/trumpkin-u123656.html
Sat Oct 17, 2009 3:43 pm
The high pressure hose is nothing fancy. The connectors are your common metric threads. It sounds like you are guessing. Verify the leak problem before you start replacing parts. Saves money and time. Check your rack if you have not already. They will leak from the seals at the ends. The fluid will exit the bellows or "boots" as some call them. If you are willing to take on a job make sure it is the problem. Your time and money are very valuable, don't waste them!
