stebo0728 »
https://forums.nicoclub.com/stebo0728-u126596.html
Fri Jul 27, 2012 8:06 pm
Those are agentine ants. They are tough, I mean tough to get rid of. They typically migrate out of the house in the summer. If you can put up a good perimeter before the fall, you might stave them off. The nasty bit is, they have no central nest, the form "nest nodes" all throughout you house, in the walls, in the subfloor, in the attic. Take down a picture and before long you'll see a line filing out of the pin hole. I use Ortho Home Defense Max, seems to work the best against them. Unless you're just grossed out by them though, just removing any water or sugar source they are after will cause them to retreat rather quickly, about 10 minutes or so. I wont say you CANT get rid of them, but you are in for a battle. Possibly fumagating would work, but you want to be sure an immiter is placed in the attic so that the fumes make it inside the walls.
