how do i check ecu codes
hungryjoseph
Car: s13 with rb25 and s13 with s14sr20
How do i check for ecu codes on an s14 sr20det "na" ecu?
fast_s13
i dont have my fsm on me right now but i know it flashes the check engine light on the dash
hungryjoseph
i checked the fsm but i can't find where it tells me how
schanne
Car: 93 Hatch-Sr20
http://www.performanceforums.c...27220
hungryjoseph
schanne wrote:http://www.performanceforums.c...27220
thanks, heres what i got
Quote »Firstly, locate the CONSULT connector. It is in the driver's side foot-well fuse compartment (the socket at the bottom on RHD cars). With the engine OFF, bridge the two pins on the top row on the right (or nearest the door is another way to put it). Now, watch the "Check Engine" light (MIL) as you start the car. There are two kinds of "flashes" and two kinds of "gaps"[/quote]what/where is the consult connector? what does he mean by bridging?
fast_s13
consult connector is like a obd port..and bridging is putting a jumper wire between those two wires to connect the circuit
hungryjoseph
Ok, I did this and I got no engine light, my problem right now is that the car is idling high, like 1200 - 1300 (yes i adjusted the idler screw) and theres some popping/misfiring going on at idle
schanne
Car: 93 Hatch-Sr20
check and/or replace all fuses. I have a buddy in town with a sr having the same problem for a while trying to figure it out replacing wrong parts. It was a fuse....
hungryjoseph
which fuse was it? I checked every one of them because the light for my clock and the buttons around the steering wheel stopped working,. and they all seemed fine, and when you say same problem? do you mean the high idle and misfire or the ecu not giving the codes
surfer240sx
Car: 90 240sx sr20det
it was the engine control fuses in the enging bay fuse box
hungryjoseph
that caused the high idle and misfire? or the ecu to not give codes?
