Hotchkis Sport Sway Bars
Installation difficulty - Easy
Install time - About 1.5 hours
Cost - approx. $300.00Specs:Front1 3/8" (35MM) Tubular Bar Weight 13.5lbs 4 Position Adjustable Rear15/16"(24mm) Tubular bar weight 5.5lbs 3 Position Adjustable
Advantages -
Bar Rates: 350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock) Hole 2 = 1845 lbs/in (48% Stiffer than stock) Hole 3 = 2270 lbs/in (82% Stiffer than stock) Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front
Hole 1 = 1525 lbs/in (5% Softer than stock) Hole 2 = 1845 lbs/in (15% Stiffer than stock) Hole 3 = 2270 lbs/in (42% Stiffer than stock) Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear (all):
Hole 1 = 520 lbs/in (80% Stiffer than stock) Hole 2 = 655 lbs/in (125% Stiffer than stock) Hole 3 = 840 lbs/in (185% Stiffer than stock)
Disadvantages - None
